Jel ima neko iskustva sa time? Neki test ako je moguce
Na PCberzi sam nashao GW 7800GS Golden Sample. Shta mislite o njoj?
http://www.pcberza.co.yu/komponente/detail.php?id=34077
Shteta shto nema neki radeon u toj klasi... x1950 je ipak preskup... :trust:
@whiplasher - hehe, mocna je to kartica, ali ja bih ipak da se odmaknem malo od SM2.0 :d
Па ако ти помаже имаш овај тест
http://www.tomshardware.com/2006/02...irms_agp_aint_dead_yet/page5.html#3dmark_2003
Иначе на сличном систему моја Inno3D 7600GST na default 5600 (500,1400), а OC 7000 (625-1800) наравно 3DMArk05, а колико видим овај 7800 је приближно ту негдје за реалне перформансе у играма не бих могао да дам поређење.
Ево нађох једно поређење
Ok, let's do a compare. Had to search quite a bit to find the 7600GT review there.
Card - min fps, average fps, max fps
Oblivion - Indoor 1280x1024
Leadtek 7600GT - 16, 42, 58
BFG 7800GS OC - 21, 40, 54
Oblivion - Indoor 1280x1024 4xAA 8xAF
Leadtek 7600GT - 17, 38, 57
BFG 7800GS OC - 8, 38, 58
Indoor the 7600GT is clearly the winner, the framerate never drop under 16 while the 7800 GS drops as low as to 8FPS at times.
Oblivion - Outdoor 1280x1024
Leadtek 7600GT - 11, 15, 29
BFG 7800GS OC - 15, 19, 28
Oblivion - Outdoor 1280x1024 4xAA 8xAF
Leadtek 7600GT - 8, 13, 16
BFG 7800GS OC - 12, 15, 23
Outdoor the 7800GS is a little faster, but with AF and AA enabled the game runs quite bad on both cards.
F.E.A.R - 1280x960
Leadtek 7600GT - 31, 55, 120
BFG 7800GS OC - 27, 51, 111
The 7600GT is faster without AA and AF enabled.
F.E.A.R - 1280x960 4xAA 8xAF
Leadtek 7600GT - 17, 29, 65
BFG 7800GS OC - 16, 31, 60
When you enable AA and AF the cards perform very equally.
Age of Empires III - 1280x1024
Leadtek 7600GT - 16, 34, 47
BFG 7800GS OC - 21, 29, 54
Once again, not much difference between the cards, the 7800GS has higher min and max fps but the 7600GT has a better average FPS.
Age of Empires III - 1280x1024 4xAA 8xAF
Leadtek 7600GT - 31, 43, 56
BFG 7800GS OC - 38, 53, 70
This is the only test where the 7800GS is clearly faster.
Conclusion: The tests aren't really comparable as they've been run with different drivers, motherboards and game versions, but even then the difference between the cards is minimal. There are also some strange results as why does the framerate go up by a lot in Age of Empires when you enable AA and AF? The cards performs about the same in almost all tests, the 7800GS wins in some while the 7600GT in others. The 7800GS might be a better overclocker and how much that is worth moneywise is something the buyer needs to evaluate, but at stock speeds there isn't much difference between the cards and thus the 7600GT offers better value for the money.
Значи на default нема разлике, 7800 се боље OC (мада мој Inno3D показује да то баш и није случај) али када узмемо цијене оба модела 7600 је бољи избор. Само да напоменем да графичке нису тестиране на истим системима тако да резултате треба узети са резервом али су ипак довољни да дају праву слику.
Heres fact:
7600GT is similar in performance to 7800GS
7600GT is cheaper than 7800GS
7600GT runs cooler, and probably uses less power
И најбоље поређење
http://xtreview.com/review140.htm
