DD-WRT Hardware Support Notes
Note: Please read the flashing notes relevant to your hardware.
1.) DD-WRT supported/tested router hardware versions
Router: Serial Number prefixes:
Linksys WRT54G 1.0 CDF0xxx or CDF1xxx
Linksys WRT54G 1.1 CDF2xxx or CDF3xxx
Linksys WRT54G 2.0 CDF5xxx
Linksys WRT54G 2.2 CDF7xxx
Linksys WRT54G 3.0 CDF8xxx
Linksys WRT54G 3.1 CDF9xxx
Linksys WRT54G 4.0 CDFAxxx
Linksys WRT54G 5.0 (JTAG only with cfe update, see http://wrt-wiki.bsr-clan.de/index.php?title=Flash_Your_Version_5_WRT54G)
Linksys WRT54GL 1.0 CL7Axxx
Linksys WRT54GL 1.1 CL7Bxxx
Linksys WRT54GS 1.0 CGN0xxx or CGN1xxx
Linksys WRT54GS 1.1 CGN2xxx
Linksys WRT54GS 2.0 CGN3xxx
Linksys WRT54GS 2.1 CGN4xxx
Linksys WRT54GS 3.0 CGN5xxx
Linksys WRT54GS 4.0 CGN6xxx
Linksys WAP v1.0 (micro only)
Linksys WAP v2.0 (micro only)
Linksys WAP v3.0 (micro only)
Linksys WRTSL54GS CJK0xxx
Linksys WRT300N v1 (v24 only)
Allnet ALL0277
Buffalo WHR-G54S
Buffalo WHR-HP-G54
Buffalo WZR-HP-G54
Buffalo WBR-G54
Buffalo WLA-G54
Buffalo WBR2-G54
Buffalo WBR2-G54S
Buffalo WZR-RS-G54
Buffalo WZR-G300N Mimo / Nfinity (v24 only)
Belkin F5D7130/7330 (2mb flash)
Belkin F5D7230-4 v1444 (2mb flash)
Belkin F5D7230-4 v1000
Belkin F5D7231-4
ASUS WL500G-Deluxe
ASUS WL500G-Premium
ASUS WL-300g
ASUS WL-500g
Motorola WR850G/GP --> see flashing notes below
Siemens Gigaset SE505 --> see flashing notes below
Siemens Gigaset SX550i --> same as SE505
Ravo W54-RT --> see flashing notes for SE505 v1 (identical to SE505 v1)
Askey RT210W --> see flashing notes for SE505 v1 (identical to SE505 v1)
3.) Linksys WRT54G/GS (any version) flashing notes:
-For upgrading from the original Linksys firmware, please use the generic mini version (dd-wrt.vXX_mini_generic.bin) and flash it from the web GUI interface. After this first flashing you can change to any other distribution, if you want.
-For flashing via the web GUI interface, always use the included 'generic' binaries. The other Linksys router specific binaries are only meant for tftp upgrades.
4.) Motorola WR850G flashing notes:
-Just use the dd-wrt.v23_mini_moto.bin for initial flashing of the motorola device using the boot wait state.
-WARNING: Never, and I say never try to clear the nvram by the mtd utility. (mtd erase nvram). This will also delete your hardware MAC adresses which aren't stored in the CFE like in other routers.
-DD-WRT itself prevents this if a Motorola router is detected, but the commandline mtd utility can still brick your router in this case
5.) Siemens Gigaset SE505 Flashing notes:
-For flashing the Siemens Gigaset SE505, you have to use the dd-wrt.v23_mini_generic.bin with boot tftp on 192.168.2.1
-Since the Siemens default settings do not fit to the Linksys/dd-wrt settings you must additionally check your configuration details after flashing.
Želim da ograničim izlaznu snagu na minimalnu potrebnu da pokrijem stan, pošto će ruter biti uključen i dan i noć, a ukućani su u principu jako protiv wireless-a, zbog zračenja.
