Izasao novi Winamp
mnogo ruzan ovaj bento skin
probah da skinem pro verziju, kad ono:
We're Sorry.
One of the products you selected has been excluded from purchase in your country.
doskocio sam im za jednoooo... 30 sec :d
impresije: vracam se opet na mmd3 skin sa defaultnog! 🙂 Nema boljeg za mene...
A sta novo donosi ova verzija?
Dobar je a skinove mozes da podesavas po tvom ukusu. Dobar je !!!
pa imas info na sajtu!Ali evo:
Winamp 5.5
* New: Bento SingleUI Skin
* New: Auto-Tagger in File Info dialog (powered by Gracenote)
* New: Album Art support, including new window for Winamp Modern skin
* New: Fully translatable Localization support
* New: WLZ (Winamp Language Zip) filetype support
* New: Global 'playback thread priority' setting for decoders
* New: Media Monitor and MP3 Blog site scraper (in Bento browser)
* New: Option to set the number of lines to scroll in the Playlist
* New: Option to not show playlist item number in classic songticker
* New: Option to not show the playlist number in the Windows taskbar
* New: Redesigned Installer
* New: Run Setup switch, winamp.exe /REG=S
* New: Unified File Editor, with Artwork tab (for mp3, m4a, wma, ogg, flac)
* New: Version History drop-down selector and Search (in About dialog)
* New: Winamp Toolbar for Internet Explorer (optional)
* New: %family% ATF string for identifying filetypes
* New: $split() ATF function for splitting x/y disc & track strings
* New: [in_mp3] Multi-channel mp3surround support
* New: [gen_ml] Tree Options tab in Media Library Preferences
* New: [ml_autotag] Mass Auto-Tagger in Send-To menu (powered by Gracenote)
* New: [ml_local] 3 pane view options in 'Add/Edit View' dialog
* New: [ml_local] Smart View Presets
* New: [ml_local] Album Art support/pane and retrieval service
* New: [ml_local] Toolbar buttons to control view options
* New: [ml_plg] Winamp Playlist Generator (powered by Gracenote MusicID)
* New: [ml_pmp] New fields, configurable filter panes & columns, 3 pane view
* New: [ml_pmp] Album Art view & support for iPod and P4S Devices
* New: [ml_pmp] Separate view for video files
* New: [vis_milk2] Milkdrop2 Visualizer
* Improved: General misc UI/Dialog tweaks & improvements
* Improved: Re-tuned and optimized classic Spectrum Analyzer
* Improved: Surround indicator in Winamp Modern skin for multi-channel files
* Improved: Classic Songticker option for Winamp Modern skin (via Config drawer)
* Improved: [in_cdda] Conductor metadata support
* Improved: [in_cdda] Handling of multiple discs
* Improved: [in_flac/in_vorbis] ALBUM ARTIST & ENSEMBLE read support
* Improved: [in_flac] Advanced Editor mode
* Improved: [in_mod] Added support for more than 256 samples
* Improved: [in_mp3] Faster metadata gathering (also speeds up ReplayGain scan)
* Improved: [in_mp4] Smoother data sent to vis & other minor tweaks
* Improved: [in_wm] Faster WMA/WMV metadata gathering
* Improved: [gen_ff] General freeform skinning engine optimizations
* Improved: [gen_ml] Collapsed/expanded state of treeview items now remembered
* Improved: [gen_ml] Skinned scrollbars in Media Library for newer Modern skins
* Improved: [gen_ml] Reordering of treeview items (via drag+drop)
* Improved: [ml_disc] Better Unicode support & other misc tweaks
* Improved: [ml_history] Unicode support
* Improved: [ml_local] Customize Columns menu for top filter panes
* Improved: [ml_local] Option to show horizontal scrollbar for top panes
* Improved: [ml_local] New 'Podcasts' view (appears after downloading a podcast)
* Improved: [ml_local] Added ISPODCAST and PODCASTCHANNEL field names
* Improved: [ml_local] Added BEGINSLIKE comparison operator
* Improved: [ml_local] Dragging of headers to sort column order
* Improved: [ml_local] Redesigned Smart View Editor
* Improved: [ml_local] Star Rating display and selection
* Improved: [ml_pmp] 'Copy to Local Media' config separated from CD Ripping settings
* Improved: [ml_pmp] Portables "Sync" can now keep podcasts updated
* Improved: [ml_rg] ReplayGain calculation support for 64, 88.2 & 96 KHz samplerates
* Improved: [ml_wire] Optional automatic downloading of new podcast episodes
* Improved: [ml_wire] Multi-select, 'Send To' menu and other general enhancements
* Improved: [ml_wire] Podcast downloads now saved in channel subfolders
* Improved: [ml_wire] Updated podcast directory
* Improved: [pmp_ipod] Now uses the iPod's podcast menu for podcasts
* Fixed: 'All supported files' showing all filetypes in Open Files dialog
* Fixed: Esc key not working in Credits & Winamp tabs of About Box
* Fixed: Long filepaths corrupted when opening Winamp via Explorer context menu
* Fixed: Oversized preference pages with large DPI setting
* Fixed: Recurrence of multiple instances bug (previously fixed in 5.3)
* Fixed: Selecting 'No' for 'Physically Remove' prompt removes playlist/mldb item
* Fixed: TV button in video window not working
* Fixed: Windows showing if switching from modern to classic skin in minimized state
* Fixed: [ASX Loader] Recursive playlist loading & case-insensitive element matching
* Fixed: [ASX Loader] Handling of entries embedded within a REPEAT tag
* Fixed: [dsp_sps] DEP incompatibility
* Fixed: [gen_ff] "Can't unload script while in script" error when switching skins
* Fixed: [gen_ff] Remember ML size when switching between Modern & Classic skins
* Fixed: [gen_ff] Transparent docked toolbars for skins using alpha-blending
* Fixed: [gen_ff] 10% opacity not applying on skins that add items to rt-click menu
* Fixed: [gen_jumpex] Crash when loading multiple files via Explorer context menu
* Fixed: [gen_jumpex] Remove Duplicate Entries action broken in pledit
* Fixed: [gen_ml] %playcount% returning Comment on drag+drop from ML to pledit
* Fixed: [gen_ml] Shift+Insert (New Playlist) and F1 (Help) keyboard shortcuts
* Fixed: [in_cdda] CDDB crash when attempting to rip a CD in a 2nd instance of Winamp
* Fixed: [in_flac] General FLAC Editor quirks (Comments field, Enter key, etc)
* Fixed: [in_flac] 24bit files don't play when 'Allow 24bit' setting is disabled
* Fixed: [in_mod] Fadeout value goes below 0.0 sec in in_mod config
* Fixed: [in_mod] Interpolator 'division by zero' crash bug
* Fixed: [in_mp3] Crash on some mp3's with corrupt ID3v2 extended headers (rare)
* Fixed: [in_mp3] Crash on loading corrupt id3v2.3 tags of a later revision
* Fixed: [in_mp3] Negative bitrate in File Info for long mp3's
* Fixed: [in_mp4] Glitch when modifying metadata on playing track
* Fixed: [in_mp4/libmp4v2] Memory leaks
* Fixed: [in_wave/libsndfile] Crash on invalid .au files
* Fixed: [in_wm] Garbage characters when editing filetypes in config
* Fixed: [in_wm] Potential DRM lockup issue
* Fixed: [ml_disc] 0 byte temp files not deleted after ripping
* Fixed: [ml_disc] Double-click drive icon in Rip & Burn not selecting tree item
* Fixed: [ml_disc] Crash when using <trackartist> in playlist filename generation
* Fixed: [ml_disc] Drag+drop from Audio CD view to Playlist Editor
* Fixed: [ml_local] (no album) items adding to Album count in Artist pane
* Fixed: [ml_local] isempty and =0 queries now return same results
* Fixed: [ml_local] Add dir to 'Watch Folders' path truncated to 64 characters
* Fixed: [ml_pmp] Inserting extra period in filename when transcoding to mp4/aac
* Fixed: [ml_pmp] Sending ansi-converted titles instead of Unicode
* Fixed: [ml_pmp] Transfer caption building when Artist metadata is empty
* Fixed: [ml_wire] Subscription Updates setting always resets to 'Never'
* Fixed: [pmp_ipod] Potential incompatability issues with latest version of iTunes
* Fixed: [pmp_p4s] 'Error In Insert' when transferring to some P4S devices
* Fixed: [pmp_usb] Slow Winamp startup when external usb drive connected
* Fixed: [vis_milk] Milkdrop DEP incompatibility
* Misc: Winamp Remote is now an installer option (ml_orb.dll)
* Misc: Moved drawing engine out of gen_ff to tataki.dll
* Misc: Moved freetype font renderer out of gen_ff to freetype.wac
* Misc: Removed deprecated .LNG Language file support
* Misc: Removed db.w5s (replaced by new Gracenote database system)
* Misc: Removed Station Info window and Prefs page
* Misc: Removed unicows.lib/dll as we have officially dropped support for Win9x
* Updated: Gracenote MusicID/CDDB v2.5
* Updated: libpng 1.2.20
* Updated: [enc_aacplus] Coding Technologies aacPlus Encoder v8.1.0
* Updated: [gen_jumpex] JTFE v0.99.2
* Updated: [in_flac] FLAC 1.2.1
* Updated: [in_mp3] FhG Decoder v4.10
* Updated: [in_vorbis] libvorbis 1.2.0
uf... čak je i novi Lite narastao na suvišnih 2.5MB 🙁
sad bi valjalo da naprave neku Micro verziju (kao Nero 😉 )
Koristim 5.5 jos dok su bili beta i mislim da je Bento i sve ostalo sto je novi winamp doneo korak u pravom pravcu.
Novi skin mi je prelep, relativno sveden (u odnosu na Modern), single UI ideja jako lepo funkcionise, Album Art je konacno tu, savrseno radi sa iPodom, notification u uglu, Milkdrop2...
Meni licno ni jedan drugi program ne moze da odradi sta Winamp moze...
Napokon su se setili da ubace vorbis i flac plaginove u lite verziju.
Lite verzija - way to go!
Uf koliko promena, koliko li tu samo novih bagova ima. Očito je tu prilično toga dodato, izmenjeno itd, samo ne znam kad ću sebe naterati da to isprobam. Kao što je nedavno rečeno, za slušanje MP3 muzike i starije verzije obavljaju posao. Problem nastaje kod onih koji žele gain regulaciju a oslanjaju se samo na tagove (novije verzije Winampa to rade manje-više slično XmPlay-u i Foobaru2000, ali starije ne). Zanimljiv je dodatak za cover grafiku, ali ja odavno u lite verziji koristim jedan plugin koji radi bezmalo savršeno (bezmalo, jer ne ume da čita Unicode MP3 tagove). Nova verzija treba i onima koji hoće nove pluginove. Nekad je dovoljno bilo ubaciti samo novi dll, više novi dll-ovi ne rade u starom Winampu (barem neki, nisam siguran važi li za sve).
Skinuo sam ga malopre, sve pohvale, jako mi se dopada, jedino shto mu zameram je to za paly listu, al nije nishta stashno vec sam nasho kako cu sad da ga drzim, jeste da ubedljivo najbolji media player (bar shto se muzike tiche) je amaroK (al *** nema ga za Win). Ali mislim da je winamp napravio vrlo velik pomak u pravom pravcu, i mnogo mi se vishe dopada prelaz sa 5.xx na 5.5 nego onaj sa 2.xx na 5.xx
To sto ne moze da se odvoji playlista od ostatka (bez obzira na to da li instalirao ili ne Media Library) je glupost! Kome bre treba browser u plejeru?!
Pa onaj kome ne treba browser ima druga dva skina u kojima sve može da se odvaja.
Slazem se! Sta je ovo, kopija Real playera, MusicMatch Jukebox? Good old Winamp rulz.
Dobro je sto i dalje ima podrsku za mp3...😀
Ma pocinje da lici na fakin iTunes...
Instalirajte 5.5 lite pa neće ličiti na iTunes. Stari dobri Winamp, classic skin + najnovije verzije input plaginova.
Da ne floodujem temu previse, al meni je AIMP prirasto za srce. Winamp je otis'o u vecna lovista. 🙂
Hmmmm... Jel moze neko (preferably sa slabijom konfom) da pogleda koliko mu 5.5 opterecuje proc? Sad slusam mp3 u VBR, opterecuje proc i do 11% 😡
Ajde da bude da o ukusima ne vredi raspravljati,ali ovaj Bento brateee....najvece djubre na svetu!😡 Pa stvarno su mogli ako nista drugo da naprave da se playlista odvaja...Sreca pa rade skinovi od dvojke i "stare" petice...***o ih Itunes i svi slicni na tu foru (mnogo glupa fora,program za slusanje muzike ti zauzme pola-ceo monitor)... uuu, bas sam besan...pa browser u winamp-u...sto kaze co'ek "Dobro je dok mp3 sljaka"...Aman,nek ostave stari dobri Winamp na miru!... Pa sta treba da bude za koju godinu? Skines Winamp a u njemu i Win i drajveri i hotfix-ovi i firefox i Dreamwiver i prime 95 i Cpu-z i Office i Nero i Nod i Super Mario???:cuss: 😡:crash::wall::wall::wall:
+1
A za nemogućnost odvajanja playliste - ravno zločinu. Nisam mogao ni da zamislim da će nekome ikada da padne takva ideja...
    29 KB · Pregleda: 110
foobar FTW! :smoke:
ko hoce da olaksa winamp maximalno, neka pogleda (nema veze sto je tweak na beta verziji): LINK
ovako to izlgeda kod mene...startuje doslovno za 1 sekund 🙂
polja visualization i dsp/effect su prazna...ovako dobijate samo mp3, wma, wmv unbloated player (meni trenutno nista drugo ni ne treba 😉)...postoje pluginovi koji ne mogu da se obrisu kao sto je crash_reporter, njega morate rucno izbrisati sa diska...
a ram mu cak ni ne treba 😀
folder ~4MB :hair:
jos nesto: u polju input mozete da izbrisete sve pluginove i da ih zamenite samo jednim sa ove adrese (koristim SSE2 verziju): http://otachan.com/in_!mpg123.html#DOWNLOAD
http://www.techspot.com/tweaks/winamp/
