Catalyst 7.9
Nedjo
VIP član
Gomilu optimizacije donose, narocito za 2400/2600 seriju:
# Far Cry performance improves up to 14 % on the ATI Radeon™ HD2900XT CrossFire™, ATI Radeon™ HD2600XT single card, and ATI Radeon™ HD2400XT CrossFire™ configurations
# Call of Duty 2 performance improves as much as 12% with Anti-Aliasing enabled on the ATI Radeon™ HD2600XT CrossFire™ and single card configurations
# Half-Life 2: Episode 1 performance improves at most 9% on ATI Radeon™ HD2600XT CrossFire™ and as much as 6% on the ATI Radeon™ HD2400XT CrossFire™ configurations.
# Serious Sam 2 performance improves up to 46% on the ATI Radeon™ HD2400XT CrossFire™ and up to 27% on the ATI Radeon™ HD2600XT single card and CrossFire™ configurations with Anti-Aliasing enabled.
# Quake 4 performance with Anti-Aliasing improves 9% or more on the ATI Radeon™ X1600/X1650Pro and ATI Radeon™ X1300/X1550 products in both single and CrossFire™ configurations
http://game.amd.com/us-en/drivers_catalyst.aspx
A tu su jos neki dodaci:
This release of Catalyst™ introduces the Avivo Video Converter for the Windows Vista (64 bit) operating system. The Avivo Video Converter is a transcoder tool that provides a quick and easy way of converting videos from one format to another. The Avivo Video Converter found within the Catalyst™ Control Center, allows the user to select the input file, and output format, along with the quality level and file location. The Avivo. Video Converter accepts a wide variety of file formats as a source, and outputs to file formats such as MPEG-1, MPEG-2, MPEG-4/DivX, WMA, H.264/AVC and more.
Kao i:
This release of Catalyst™ introduces Color Temperature Control within the Catalyst Control Center, allowing users to adjust the chromatic level shown on their display. Supported on the ATI Radeon™ X1000 Series and Radeon™ HD 2000 Series of products.
A ispravljena je i gomila bagova za Vistu:
# Bioshock: Missing, blackout, and flashing surfaces are no longer noticed in the game. Further details can be found in topic number 737-29549
# Bioshock: Random polygons shooting up in the sky are no longer noticed. Further details can be found in topic number 737-29551
# Gods: Land of Infinity (demo): Having the in-game options set to 1920x1200 32bpp, Shadows on High, and Texture Quality set to High no longer results in only the mouse pointer being visible. Further details can be found in topic number 737-28810
# LostPlanet: Display flicker is no longer noticed when playing the game under the Windows Vista operating system. Further details can be found in topic number 737-29560
# Monsters.Inc: Enabling DXVA no longer results in certain game scenes appearing choppy. Further details can be found in topic number 737-29546
# Prey: Texture tearing is no longer noticed in certain areas of the game. This issue was known to occur on ATI Radeon™ HD 2x00 series of products. Further details can be found in topic number 737-29563
# Quake3: Moving the mouse pointer over the options listed in the System Setup no longer results in the option being highlighted and the option being overdrawn by the highlight. Further details can be found in topic number 737-29531
# World of Warcraft: Playing the game with wide or narrow tent Anti-Aliasing filters no longer results in wireframe flashing. Further details can be found in topic number 737-28807
# Attempting to enable CrossFire™ on a secondary display device no longer results in CrossFire™ failing to be enabled. Further information on this issue may be found in topic number. Further details can be found in topic number 737-28844
# Windows Dream Scene Content: Corruption is no longer noticed when attempting to run the preview for the chosen clips. Further details can be found in topic number 737-28856
# The ATI resolution and color text "mouse over" dialog box no longer contains a mix of English and Arabic. Further details can be found in topic number 737-28811
# Playing an HD-DVD title using the Cyberlink player no longer results in corruption or the Windows Vista operating system failing to respond after a short period of playback time. Further details can be found in topic number 737-28827
# Using WinDVD or WMP11 to playback a DVD title with subtitles enabled no longer results in the edge of subtitle appearing transparent. Further details can be found in topic number 737-29533
# Hot-plugging an HDMI display device to a system containing an ATI Radeon™ Xpress 12x0 series of product no longer results in the HDMI display device failing to be detected under the Windows Vista operating system. Further details can be found in topic number 737-29535
# MediaDirect no longer displays corruption prior to Blu-ray movies starting. Further details can be found in topic number 737-29544
# Enabling Overlay Theater Mode no longer results in tearing and choppy playback being noticed when clone mode is enabled. Further details can be found in topic number 737-29557
# Attempting to playing a DVD title using WinDVD 7 and enabling hardware acceleration no longer results in the DVD failing to play. Further details can be found in topic number 737-29558
# Setting the secondary display device to primary and the primary to secondary no longer results in the display swapping failing after enabling extended desktop mode. Further details can be found in topic number 737-29559
# Tearing artifact is no longer visible on OTM display when playing back any video using Overlay with OTM enabled. Further details can be found in topic number 737-29561
# Google Sketchup no longer has an incorrect cyan colored X-axis. Further details can be found in topic number 737-29562
# Cyberlink HD playback: Performing a mode change when playing a video no longer results in the video playing at various speeds. 737-29564
# Overlay Theater Mode settings are no longer grayed out when the desktop is set to display resolutions of less than 1024x768. Further details can be found in topic number 737-29571
# A Tuner Not Available error message is no longer displayed when starting MCE after installing the ATI driver and video decoder. Further details can be found in topic number 737-29572
Kao i za XP:
# Adobe After Effects 8.0: The Fragment Shader no longer fails when rendering shadows. Further details can be found in topic number 737-29565
# Bioshock: Frame stutter associated with time spikes in random components of the render stats is no longer noticed as the character walks around. Further details can be found in topic number 737-29041
# City of Heroes: Attempting to play the game on a system running Windows XP no longer results in the game failing to launch when using an ATI Radeon™ HD 2600 XT. Further details can be found in topic number 737-29567
# City of Heroes: Enabling CrossFire™ followed by attempting to launch the game no longer results in the game failing to launch and the operating system failing to respond. Further details can be found in topic number 737-29568
# PowerDVD: Playing a DVD on a system containing an ATI Radeon™ HD 2400 series of product no longer results in missing pixels being noticed on the DVD menu selection. Further details can be found in topic number 737-28511
# World of Warcraft: Intermittent flashing is no longer noticed when enabling AA. Further details can be found in topic number 737-29569
# Setting the display device to 1280x1024 and attempting to playback a VC1/h.264 title using the Cyberlink player no longer results in choppy playback. Further details can be found in topic number 737-28832
# Corruption is no longer noticed when playing wmv files with WinDVD when CrossFire™ is enabled. Further details can be found in topic number 737-29566
ATi rul3z, nema ludjih od njihovih inzhinjera. ;)
:banana:
Ja imam problema sa ovim drajverima,naime izbacuje cli.implemetation error poruku na startup-u ili kad ocu da pokrenem CCC izbaci ili ovu gresku gore ili MOM.implemetation error probao na X850XT mojoj karti i na Ati X1200 integrusi,instalirao sam netframework 2.0 i 3.0 i dalje imam problem,svaka pomoc dobrodosla :)
pozz
Taman sam se zaleteo da pomenem net framework, ali očigledno nije u tome fora...
ko ima r9600pro i igra eve-online neka preskoci ove drajvere
cim se startuje eve, zacrni se ekran i na svakih par sekundi se 'resetuje' monitor (nesto slicno kao da se pali i gasi), zbog cega je to tako, nemam pojma, vratio sao 7.1 i sve radi ok
Definitvno nesto nevalja sa ovim drajverima,e sad nek se javi neko sa 2600pro/xt ili 2900 kartama i da nam kaze dali ima isiti problem,ili su drajveri namenjeni samo najnovijim kartama.
pozz
sa 2600 xt radi sve osim mom.exe nece da se pokrene mada i ne treba vam monitoring sistem :D
Ja sa 7.9 nemam ama baš nikakvih problema.Koristim Vistu.
Stavio ih na 1650xt, rade extra! :smoke:
Sa 2600xt radi savršeno,ni jedan problem.Koristim XP.
U 3dmark05 daje nekih 50-tak poena više nego 7.8.
@cranky
instaliraj netframework 3.0 pre instalacije drajvera
instaliracu samo da nadjem cd od winblowsa moram reinstalirati sistem jer sam konacno nasao sta koci dizanje mreze uh napatio sam se ko niko :D
Ovaj Control Center je sve gori, srećom pa ATI Tray Tools radi sve poslove oko podešavanja drajvera.
Hm ne vidim da je nesto gori, 1950GT daje bolji skor u 3d06 i lost planet ide nesto bolje.
his 2600xt, sve radi ok.
ovde palo masovno brisanje i mass unsubscribe ili sam istripovo ? :p
Jel zna neko gde ima da se skine neki novi (update) decoder za AIW modele?? Imam X800xt AIW i puno problema sa zvukom, pa me zanima da li postoji novija verzija fajla setup.exe koji se pokrece iz atiwizard-a....
Naime... na nekim kanalima (i bas na b92 koji najcesce gledam) imam smetnje, recimo kada je neki prenos utakmice... ne daj ti boze....
PS: Stavljeno mi je podrucije GERMANY i nista...... a cini mi se da se pri prvom startu sve cuje ok, ali posle sve pogorsa...
koju app koristis za gledanje TV-a ? Jesi probao DSclaer ili Chris TV ? Ona atijeva aplikacije nije bas najsretnije resenje...
jedno pitanje za one koji imaju x19xx da li vredi stavljati 7.9 ?
da ne restartujem racunar za dzabe.
Koja se verzija pokazala ok za 9600xt ?
OpenGl i hd2600 pro
Posle instaliranja nove kartice (GigaByte hd2600 pro), ne mogu da mi rade neke starije igrice (Call Of Duty, Soldier Of Fortune II). Nesto javljaju da je problem sa OpenGl-om i da proverim da li imam najnovije drajvere za graficku. Sa adrese www.ati.com sam skinuo nove drajvere i Ati Catalyste 7.9 ali je i dalje isto. Definitvno tu nesto sa necim nije u redu. Da li neko ima ideju sta moze da bude?
Isti problem imam kao MHZ, nikako da pokrenem drajvere :mad:
Veliki problem
Uzeh juce Radeon 2600PRO DDR3, ali nikako da instaliram drajvere, ako instaliram 7.9 samo display drajver onda taj drajver je nekako lose instaliran, pokazuje mi da kartica ima 512 ddr, a ona nema ima 256, zatim ati tool ne moze da prepozna verziju drajvera, 3dmark ni 05 ni 06, nece ni da se pokrenu??? Control centar se kao instalirao, ali posle ne moze da se pokrene izbaci neku poruku da mu nesto fali i jedno ok.
Masina iz potpisa, nforce drajveri 6.86. Pre toga sam imao Nvidia graficku, ali sam drajvere deinstalirao ocistio registry driver cleaner pro programom, pa tek posle toga mnogo puta pokusao da instaliram ove drajvere ali avaj :cuss:
Za pocetak uninstall drajvera Driver Cleaner-om. Onda lepo prvo instaliras Microsoft Visual C++ 2005 Redistributable ili kako vec i NET Framework 2.0, pa tek onda instaliraj drajvere i CCC. Ja sam se prvi put z****o i morao sam da dizem novi win.:wall:
A sto se 3DMark-a tice koristi search.
Meni se chini da pokazuje zato sto kartica ima hyper memory, ili kako se vec zove ono sto uzima ram za vram. A sto se tice control centera treba ti net framework 2.0, to skini sa neta. A za mark 06 treba da renajmujesh neki fajl, ima tema u kojoj to vec pishe
Hvala puno ljudi, ovo su novi momenti, sada cu pokusati sve to da sredim, hvala jos jednom!!!
