kamikaza011
cena:280eur
cena:280eur
Za novosadjane, ima svi izlozheni u Windows-u na Spensu i svi su upaljeni![]()
Daj iz donjeg ugla
Jedinu ozbiljnu manu koju sam ja nasao je ono malo led svetlo i iz nekog razloga me toliko nervira da cu morati da ga prelepim necim...
A Typhoon.X-u hvala za opis istog sto je bio presudan faktor u kupovini ovog monitora.
Wikipedia je napisao(la):The DVI interface uses a digital protocol in which the desired illumination of pixels is transmitted as binary data. When the display is driven at its native resolution, it will read each number and apply that brightness to the appropriate pixel. In this way, each pixel in the output buffer of the source device corresponds directly to one pixel in the display device, whereas with an analog signal the appearance of each pixel may be affected by its adjacent pixels as well as by electrical noise and other forms of analog distortion.
Kompletan tekst
Kao prvo, razlika nije 50e, vec nekih 30-tak (bar kod LG-a). Kao drugo, kada je display veza preko DVI prikljucka, signal se salje precizno za svaki pixel i nije podlozan smetnjama i distorzijama.
koji je firmware u pitanju? ima li onih RTC gresaka sto se pominju na x-bitlabs-u?
