Opera 9.5 alpha 1 (kestrel)
illidan
- Bike Camper -
CPU & Cooler
amd 5800x3d, cm atmos 240 - phanteks t30
Matična ploča
asus rog strix b550-i gaming
RAM
g.skill trident z neo 32gb cl16 3600
GPU
nvidia rtx 4070super founders edition
Storage
samsung 980 pro 1tb, wd black sn770 2tb
Zvuk
ifi zen dac v2 - fosi audio za3 - kef q350, fiio ft1, all balanced
PSU
corsair sf750 platinum
Kućište
lian li a4 h2o
Monitor
gigabyte mo27q28g
Miš & tastatura
g-wolves hts plus pro 8k, kbd.fans tofu65 raw alu - cream soda switches - gmk serika 2 keycaps
Pristup internetu
  1. Optički internet
Release Notes
This is an alpha version of Opera. Use only on properly backed up computers and do not install over previous Opera versions
This release uses new storage and indexing formats for Opera Mail (including newsfeeds). If you copy your Mail directory from an existing profile, you will be prompted to convert all accounts into the new format and re-index your messages. You will not be able to downgrade to a previous version of Opera after starting the conversion process
Known issues
Kestrel does not currently run on Windows 95B
POP server cleaning has been disabled: When disabling the "Leave messages on server" option, existing messages on the server are not removed
[BUG 274975] Graphical smilies do not work
[BUG 280261] Removing messages from filters does not work
[BUG 277681] Some order lists are displayed as unordered lists
[BUG 279302] Line wrapping does not work correctly in some cases, causing overly long lines of text and horizontal scrollbars; often seen at Wikipedia
[BUG 280678] Files are often saved with the incorrect file extension
[BUG 213115] Queued mail is sent at the next check, instead of waiting for manual action
[BUG 281550] Setting an external source viewer does not work
windows: http://snapshot.opera.com/windows/o950a1_9500_en_cl.exe
mac os x: http://snapshot.opera.com/mac/o950a1_4404.dmg
linux: http://snapshot.opera.com/unix/9.50-Alpha-1/
Prvo, nikome ne preporucjem da koristi aktivno ovu alphu. Stavise, ako ne nameravate da lovite bugove, nemojte je instalirati.
Sad malo zapazanja posle nekoliko dana koriscenja:
- Teze se startuje, primetno vise vremena je potrebno.
- Posle kraceg vremena rada zauzima relativno mnogo memorije i procesorskog vremena. Juce mi se desilo da je CPU bio zakucan na 100% konstantno, a RAM zauzece ~440MB.
- HDD ima tendenciju da raducka povremeno kad je Opera startovana.
- Precice na tastaturi su skroz poremecene. Ctrl+B, Ctrl+H na primer otvaraju Bookmarks i History. Nadam se da ce ovo vratiti na staro, ne pritiska mi se Ctrl+Shift+B.
- Ponovo "feature" koji je postojao u verziji 9.00: kad se sacuva neka slika, otvara se transfers prozor.
- Na svakom startu programa nudi da se mail baze upgradeuju na novi format. Dok se to ne uradi, svaki put cete dobijati Yes/No prozor. Kad izaberete Yes, delovace da se nista ne skida. U svakom slucaju, nece vise smarati, ako ga tada ponistite.
- Navigation bar, koji sam ja popunio precicama za sajtove (prevlacenjem iz tab bara), ume da pobrljavi tako sto zagubi razmake koje sam stavio izmedju odredjenih grupa sajtova (forumi, webmail, d/l sajtovi,...) i to potpuno nasumicno, da iam razlike izmedju dva taba.
- Nisam primetio neka poboljsanja "ispod haube", tj. ne osecam da je nesto dodatno uradjeno na polju brzine ucitavanja strana. Skrolovanje je bolje, mozda se nece svideti svakome, kao da skrol skakuce (pricam za skrolovanje tockicjem misha). Brze je skrolovanje kursorskim tasterima. Koliko mi se cini, bolje se snalazi sa vecim brojem slika na strani.
1. kod mene se isto startuje kao i 9.23
2. maximum mi je zauzela 280MB
3. samo kada je neka glomazna stranica (mnogo slika, i sl, valjda keshira stranice)
4. kod mene radi i ctrl+b i ctrl+h
5. kod mene ne otvara transfer prozor kada snimam sliku
6. ovo se kod mene ne pojavljuje uopste
7. ne koristim bas mnogo precice za sajtove (lakse je snimiti session)
8. ima poboljsanja meni je sa ovom verzijom osetno brzi browsing nego sa 9.23 (ali i dalje ima nekih bugova)
***a alpha verzija. i ne preporucuje se pregaziti staru operu ovom verzijom
