gvlada
Ko zeli full potencijal X-Fi u Visti trebalo bi nabaviti najnovije drivere sa Creativovog sajta, onda skinuti Dell driver kod kojih radi AC3 decodiranje i YouP-PAX tj. X-Fi2 suite. Dobija se kompletna mogucnost kao i pod XP. Samo mi nije jasno zasto to Creativ sam ne izbaci na svom sajtu.
X-Fi driver sa sajta: http://yu.europe.creative.com/support/downloads/
X-Fi2 suite (660MB): http://www.youp-pax.org/viewthread.php?tid=362&extra=page=1
files koji nedostaju su attach a uputstvo:
Download the file and extract it to a directory. Mount the ISO with any virtual drive which supports it and then setup according to the instructions given. If setup menu doesn't pop up, Go to virtual drive and run PAXSetup.exe to start installing.
NOTE:
1. Do NOT execute installation by directly clicking SETUP.EXE in this ISO, otherwise a few setting won't work for you.
2. If you have installed Creative Alchemy, copy both dsound.dll and dsound.ini of it to EAX game's directory and overwrite the same files. These two files have to appear with game exe file. eg, these two files are with where some exe files are in BIN directory.
3.Drivers in this software setup is developed for Vista in which AC3/DTS decoders are not available. Hence please discircle "Windows Drivers" in Customized installation and install other drivers instead.
4.Please switch off all antivirus before installing.
Download the drivers from http://ftp.us.dell.com/audio/R144728.EXE then u a program like winrar to extract that exe file to a folder, there should be the folder path /drivers/wdm/win2k_xp then in there if you have 32 bit vista, use the folder i386, if you have 64-bit vista use the folder amd64 copy the file ctac32k.sys to c:\windows\system32\drivers (overwrite if necessary). Then, restart the computer. Go to device manager, make sure you have it set to display hidden devices. Look for Creative AC3 Software Decoder. Double click that. Then on one of the tabs there should be a start/stop button. Make sure you stop it then start it again.
After that was set up I downloaded the youp-pax software setup. http://youppax.shcsclan.com/YouP-PAX-X-FI2007.rar after that's done downloading, make sure to go through the steps selecting Windows Vista, and deselecting installing the drivers (since theyshould already be installed) I needed to deselect the entertainment center too because setup hanged on installing that for some reason. When the installation is complete, restart your computer.
Open up the audio console, check the tab where it allows you to select what to dowith the spdif inputs, and change it to dolby/dts decode. Make sure you set up the dolby/dts decoders in their tabs too. After this you should be able to get Dolby Digital and DTS from your spdif/digital-in ports
Prvo instalirati driver sa sajta, pa zameniti files pa onda X-Fi2 suite i tu destiklirati audio drivers, vec su instalirani.
NOTE:
