VexMunja
Dizem temu iz mrtvih...Buaaaaa:d:d:d
Od sinoc mi S.M.A.R.T. prijavljuje tu gresku" Spin retry count",vrednost 97 (a dosadasnja 95)
iz HD Sentiel-a:
1,Raw Read Error Rate,6,116,87,OK,000000000000,0,Enabled
3,Spin Up Time,0,96,95,OK (Always passing),000000000000,0,Enabled
4,Start/Stop Count,20,100,100,OK,0000000001A3,0,Enabled
5,Reallocated Sectors Count,36,100,100,OK,000000000000,0,Enabled
7,Seek Error Rate,30,45,43,OK,1325075AA905,0,Enabled
9,Power-On Time Count,0,96,96,OK (Always passing),000000000ECE,0,Enabled
10,Spin Retry Count,97,95,95,Pre-Failure: Data loss predicted,000000000000,0,Enabled
12,Drive Power Cycle Count,20,100,100,OK,0000000001DB,0,Enabled
187,Vendor-specific,0,61,61,OK (Always passing),000000000027,0,Enabled
189,Vendor-specific,0,100,100,OK (Always passing),000000000000,0,Enabled
190,Airflow Temperature,45,63,54,OK,0000261A0025,0,Enabled
194,HDD Temperature,0,37,46,OK (Always passing),001100000025,0,Enabled
195,Hardware ECC Recovered,0,65,56,OK (Always passing),0000001A1355,0,Enabled
197,Current Pending Sector Count,0,1,1,OK (Always passing),0000FFFFFFFF,0,Enabled
198,Off-Line Uncorrectable Sector Count,0,1,1,OK (Always passing),0000FFFFFFFF,0,Enabled
199,Ultra ATA CRC Error Count,0,200,200,OK (Always passing),000000000000,0,Enabled
200,Write Error Rate,0,100,253,OK (Always passing),000000000000,0,Enabled
202,Data Address Mark Errors,0,100,253,OK (Always passing),000000000000,0,Enabled
Jer ima neko iskustva sa ovakvim simptomom i dali da se nadam cirkavanju harda ili da cooliram?:trust:
iz HD Sentiel-a:
