wiz011
Guest
Free zamena za Adaptecov wnaspi32.dll. Mislim da će ovo mnogima uštedeti glavobolje sa ASPI-jem:
http://www.frogaspi.org/
Ako neko hoće da ima kompletnu ASPI instalaciju onda mu trebaju još tri Adaptecova fajla, pa evo da znate gde koji ide:
aspi32.sys = %windows%\system32\drivers
winaspi.dll = %windows%\system
wnaspi32.dll = %windows%\system32
wowpost.exe = %windows%\system
Ako instalirate na čistu mašinu, poželjno je i ovo:
The ASPI Manager is the software that supports the ASPI interface. ASPI drivers call ASPI functions to access SCSI peripherals. The ASPI Manager for the SCSI host adapter processes these function calls and generates the appropriate SCSI commands to the SCSI peripherals.
Some ASPI are available on the net, but both have limitations :
- You must have materials from a specific brand (Adaptec)
- You can't use it with writing softwares (Ahead)
- Doesn't support correctly USB/Firewire drives...
For all these reasons, I've decided to write my own ASPI manager, and to distribute it freely without any usage limitation.
FrogAspi is a FREE replacement of wnaspi32.dll
REGEDIT4
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ASPI32]
"ErrorControl"=dword:00000001
"Start"=dword:00000001
"Type"=dword:00000001
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ASPI32\Parameters]
"ExcludeMiniports"=""
