Problem sa INTERENT Sharing-om
djwibe
DVA RACUNARA OD KOJIH JE PRVI (SERVER) PREKO USB-a NAKACEN NA MODEM ( CABLE FLAT 256/512 )I POVEZAN SA DRUGIM PREKO UKRSTENOG KABLA (LAN).
DODELIO SAM INTERNET KONEKCIJU, ALI DRUGI KOMP NECE NA NET.
PROBAO SAM I SA TRECIM RACUNAROM (LAPTOP) I ISTO NECE DA SE KONEKTUJE.
STA MOZE BITI PROBLEM I KAKO GA RESITI.
Koliko se secam, moras "serveru" da das manualnu ip adresu 192.168.1.1, a dugi racunar mora da bude automatic...
Poz. Rile
Reseno. Drugi Komp Nesme Da Bude Sa Fiksnom Ip Adresom Vec Na Auto.
Thanks Rile.
cek cek.. koja se mreza podesava tj menjanje ip'a na glavnom a na pomocnom na auto to se podesava na modemima ili na mreznim karticama?imam isti problem ali nesto mi ne ide od ruke..
reseno:d stavlja se na automatik ip na mreznoj...
Na glavnom kompu ides na network card i podesavas sledece.
IP Address: 192.168.0.1
Subnet mask: 255.255.255.0
Na drugom kompu podesavas sledece.
IP Address: 192.168.0.2
Default gateway: 192.168.0.1
Preffered DNS Server: 191.168.0.1 (IP Prvog-Servera)
