JoeKuboj
Posedujem Cisco-Linksys AG241 ADSL ruter, i sve lepo radi osim jedne stvari - neće Enemy Territory da se nakači ni na jedan server.
Pročitao sam upustva ovde i ovde , ali ET i dalje odbija saradnju (kada pokušam da se konketujem samo odbrojava ono Awaiting challenge...1...2...3 itd). ET-u nisam menjao port i koristi defaultni 27960.
Ruter ima firmware 1.00.04, i nema kao na slikama iz prvog uputstva Both za Single Port Forwarding, ali ima na Port Range Forwarding. Ne verujem da ovo predstavlja neki problem, pošto drugo uputstvo kaže da treba samo UDP. Elem, ja sam probao i UDP i TCP, kao i sve portove od 26000 do 28000 da isforwardujem ali jok.
Postoji i noviji firmware (1.00.23) ali ne vidim ništa epohalno novo:
Sve ostalo što se forwardovanja tiče radi normalno (torrenti, ostale igre), na ruteru je isključen DHCP, uključen firewall (probao i sa isključenim), Beotel ADSL, i tako to.
Help :wave:
Kod:
Firmware version 1.00.23
- Fixed error messages that display for PPP authentication and other GUI
issues not allowing to save settings
- Fixed RFC1483 Bridged failure to connect when set to static WAN IP
- Fixed VPN issues with passing traffic under PPPoA; IPSec Tunnel
crashing after 2~4 hours; Gateway not re-establishing connection
- Fixed PPTP Pass-through
- Added ô:ö as an acceptable character for PPP password
- Added modulation selection for DSL
- Allowed WAN IP to be the same as Gateway IP for RFC1483 Bridged Static mode
- Fixed DHCP server not responding after the LAN IP is changed to different
a subnet
- Fixed problem with settings PPPOA MTU value to 1500 under manual mode
- Fixed problems with GUI setting changes done using HTTPS remote-management
Firmware Version 1.00.04
- Initial release
Help :wave:
