Highl1 je napisao(la):
izashao je i 3.0. Korisnici sbb-a mogu da ga skinu sa torrenta u lokalu, 980MB tezak
U bre al ga pretera
Superpatch 3.0 Update out now
---- Read this Informations carefully ----
Take 15 Minutes of your Life and read this Information
carefully and you will have the best Pro Evolution Soccer 5
all the time
Some Words (Read carefully)
- You need Superpatch 2.0 before you can install this !
You can find Superpatch 2.0 here:
http://forums.evo-web.co.uk/showpos...959&postcount=1
- Respect our work !!!
We do not get money for it and that everything
in our space time made thereby for your fun, working hard for your success
- This Patch will update Superpatch 2.0 with:
update Stadiums, new Bootpack, new Optionsfile (Wintertransfers till 9/2/06)
New Online Database, full Kitserver (update Kits), new Minikits
- Don´t flame any Forum if you don´t follow this Instruction 100 %
- We don´t update any Faces so if you update some Faces by yourself, this Optionsfile
maybe remove some of your new imported Faces and set them back to default Face.
- We don´t support any Facesproblem, all Faces working fine, with Faces on Superpatch 2.0
- Working hard for your success
- Remember You need to use opponents they have also install Superpatch 3.0
- If you like to use the Online Database from Superpatch 2.0 go to: Step 6
at the bottom of this instruction
FAQ:
- You have to start a new Master League after install this !!!
- Be sure you have following all Steps before you flame the Forums
- My Game crashs ? : Remove/Delete some Replays from your save/folder1 Folder
- My Kits are Black ?: You don´t have installed Kitserver correctly. Repeat "Step 5"
- Kitserver don´t work for me, or i got stretched Kits: Be sure you have run setup.exe in the kitserver folder
- I have old Database ?: You have forgot: "Step 1"
- My new Faces are don´t correct: You have to reimport all your new Faces, you have import after Superpatch 2.0 again, we don´t update any Faces on Superpatch 3.0 - Faces are base on this Optionsfile
- The Optionsfile contains 99000 Points and the PES shop are locked
you can buy in the Shop what you want
- My Buttonsettings are change ? Go to Buttonconfiguration Menu in the Game
and change them back
- I miss the other balls ? Go to PES Shop and buy the balls etc.
- How can i be sure that this work online ?
the best way is to name the room sp 2.0, sp 3.0, superpatch 2.0
or something like this
- Where i can find Information about installed Superpatch 2.0 ?- Go here -->
http://www.gbase.ch/forum/viewtopic.php?p=46606#46606
__________________________________________________ _______________
Install:
Step 1 - Superpatch 3.0 Optionsfile.exe
Step 2 - Superpatch 3.0.dkz
Step 3 - pes5.exe+lodmixer 1.6
Step 4 - Minikits
Step 5 - kitserver
Optional:
Step 6 - Database Superpatch 2.0.dkz
Step 7 - Database Superpatch 3.0.dkz
Instructions Step by Step for Noobs :study:
Step 1: Superpatch 3.0 Optionsfile.exe
This Setupprogramm will install the Optionsfile for Superpatch 3.0:
Save your old Superpatch Optionsfile, if you have edit by yourself, before continue
- Click Superpatch 3.0 Optionsfile.exe to copy the new Optionsfile
If Setupprogram have finshed please click:
Step 2: Superpatch 3.0.dkz
be sure you have install DKZ Studio 0.90 or
Download from here:
http://rapidshare.de/files/6805934/DkZ_Studio.rar
and install them
- Click on "Superpatch 3.0.dkz"
- DKZ Studio will open automaticly
- Go to: Patch -->Aplly Patch in Folder
and use the /dat Folder where you have installed the Game.
- Click OK
- Finshed Import updated Stadiums, Bootpack, Online Database
Step 3. PES5.exe + Lodmixer 1.6
The new PES5.exe contains a new Stadiuminformation about
stadiums buildingdate and the capacity of each stadium.
This are the Original PES5.exe you need Original DVD for Play !!!
Step 4. Minikits
- Open DKZ Studio and open example: "e_text.afs" and go to:
Edit ---> Import--> "Import all Files" and search for the
new "Step 4 - Minikits" Folder --> Click Ok
Step 5. Kitserver (Update all Kits)
if you have install kitserver before, you have to totally delete or move your old
"KDB" Folder in kitserver Folder and copy the new "KDB"
in you kitserver Folder.
Again: Don´t copy the File simply over the old one, you have to completly remove
your old KDB Folder !!! And move the new "KDB" Folder in kitserver folder
Is this the first time you use kitserver you have to do this:
1. Installation kitserver
As usual: copy the entire kitserver folder into your game folder, so
that the directory structure looks like this:
dat/
kitserver/
PES5.exe
readme.htm
settings.exe
Go to kitserver folder and run setup.exe. The "PES5.exe" in the
drop-down list should be pre-selected, so just press "Install" button.
The kitserver should show a message box saying that the installation
was successful. (If you get an error message, make sure that you
not currently running the game, and that the PES5.exe file is not
marked as read-only)
Finshed: Have Fun
= Optional =
Step 6: Database Superpatch 2.0.dkz
- if you can´t find opponents on Online Lobbys use the Database from Superpatch 2.0
- yust click Database Superpatch 2.0.dkz, the Database are use the Database from
Superpatch 2.0, if you are finsihed
- but think about that it spend 5-7 Days if all User, have installed the Superpatch 3.0
Step 7: Database Superpatch 3.0.dkz
- This will bring you back the Database for online Gaming on Superpatch 3.0
it´s the same Database inside "Step 2"
Credits:
Thx to: "skip-br" for the new Tool about Stadium information you can find his Thread here:
http://forums.evo-web.co.uk/showthread.php?t=28497
Thx to: waldaz, Spooky for updated Database, Kitserver, Bootpack
Thx to: Zeus, Frenkie for update Stadiums
Thx to: Christophe for the Minikits
Thx to: Bonaventurstar for Main Kitserver Packed
The Superpatch Crew 10/2/2006
P.S. - We don´t update this anymore with Clubteams
- At End of May we wanna release a updated Optionsfile with correct Roster of
the Nationalsquad for World Cup 2006 Teams
Download Links for Superpatch 3.0 (94 MB)
Mirror 1 (Filefront):
http://files.filefront.com/A_Superp...;/fileinfo.html
Mirror 2 (Rapidshare):
http://rapidshare.de/files/12947966...ch_3.0.exe.html
Mirror 3 (Filefront)
http://files.filefront.com/Superpat...;/fileinfo.html
Mirror 4: (Megaupload)
http://www.megaupload.com/?d=MW1VM07R
Optional:
The same Optionsfile as above but with Shop locked and 0 Points:
http://rapidshare.de/files/13012016...Points.exe.html
