- AMD X4 @ 3,5Ghz
- GA-990FXA-UD3
- 32Gb DDR3 @ 1666Mhz
- Strix RX480 8Gb
- 256Gb 850Pro + couple of AliExpress SSD's
- Zvuk
- Creative
- Zalman ZM600-HP (Heat-Pipe :) )
- Alexander Weiss (glass front + glass side)
- Monitor
- AOC 32" IPS
- Miš & tastatura
- G602 & Drevo 87 key (Red Switch)
- Mobilni telefon
- Moto G9 Plus
- Kablovski internet
http://www.gsmarena.com/compare.php3?idPhone1=8571&idPhone2=6885
Osnovno:
Razlike između Nokia 6 modela:
(TA-1000 vs TA-1003):
http://nokiamob.net/2017/06/15/hmd-explains-why-you-shouldnt-buy-nokia-6-ta-1000-outside-china/
Izvori:
http://www.teamandroid.com/2017/08/04/nokia-6-model-numbers-variants/
https://www.nokiacamp.com/hmd-minor-hardware-software-changes-nokia-6/
Nokia 6 Drivers:
http://gsmusbdriver.com/nokia-6
http://www.teamandroid.com/2017/08/21/download-nokia-6-drivers/
Osnovno:
- Android 7.1.1 (Nougat)
- Qualcomm MSM8937 Snapdragon 430
- Octa-core 1.4 GHz Cortex-A53
- Adreno 505
Izvor:The difference between TA-1000 and TA-1003 is that the TA-1003 variant comes with Google services, while the TA-1000 doesn’t have Google Apps and uses a customized Android Nougat that follows the guidance of the Chinese government.
Model Number | Region | Sim Sockets | WCDMA Bands | LTE Bands | HAC |
TA-1000 | China (No Google Services) | Dual SIM | ? | ? | ? |
TA-1003 (4Gb/64Gb) | Hong Kong and Taiwan | Dual SIM | ? | ? | ? |
TA-1021 | Global Variant | Dual SIM | 1/2/5/8 | 1/3/5/7/8/20/28/38/40 | Not Support |
TA-1025 | Global Variant | Dual SIM | 1/2/4/5/8 | 2/3/4/7/12/17/28/38 | Support |
TA-1033 | Global Variant | Single SIM | 1/2/5/8 | 1/3/5/7/8/20/28/38/40 | Not Support |
TA-1039 | Global Variant | Single SIM | 1/2/4/5/8 | 2/3/4/7/12/17/28/38 | Support |
Nokia 6 Drivers:
