Prečistač vazduha
Elem, suma sumarum je sledeća posle prve večeri.
Sobe se prijatnije osećaju nakon spavanja. Oseća se da je vazduh ustajao, naravno, ali nema istu "težinu" kao pre. Mali je 80% manje kijao nego inače. Nadam se da će totlano prestati. Za sad smo zadovoljni. Ovo je ipak jedno veče i možda je placebo ili nije realno. Videćemo za neki dan.
PRO H naručujem sledeće nedelje. Samo vagam da li da uzemm još jedan mali 3h za dnevnu od 30ak kvadrata, ili da pustim PRO H da filtritra i nju uz hodnik i kuhinju, pa koliko dosegne.
Još jedna od mera u borbi protiv prećišćivača je Palma Areca (ili Areka, ne znam sada), koju ćemo isto "posaditi" na par mesta u kući.
Major indoor air pollutants removed by this plant are acetone, xylene, and toluene from indoor air (1). A major source of acetone indoor is from petroleum and diesel products, nail polish, paints, detergents, adhesives and cleansers, etc(2). Xylene is also one of the major indoor air pollutants mainly accumulates because of poor ventilation, paints, and wooden furniture (3). Toluene causes central nervous system disorders and necrosis mainly in children. Toluene also affects pregnant women and thus causes developmental disorders in newborns and fetuses. Other common symptoms of toluene in the body are irritation of the upper respiratory tract and eyes. Again the major source of indoor air pollution are paints, cosmetics, and gasoline, etc (4).
https://foodthesis.com/areca-palm-health-benefits/
Plant air-purification effect to reduce formaldehyde in a real office environment was examined. A potted Areca palm (height: about 2m) was adopted as a subjective plant. Plant purification effect was evaluated using a tin oxide gas sensor and a commercial tool for formaldehyde measurement was also used. The effect became higher as the atmospheric formaldehyde concentration was higher. The concentration became lower as the plants were installed. The effect did not greatly increase when the number of the installed pots was increased to seven from four. Concentration of carbon dioxide increased up to 450ppm by placing the pots at night. It is, however, below the regulated value (1000ppm) of Japan building managing law. Light intensity in the room fluctuated periodically and the carbon dioxide concentration changed periodically according to the fluctuation of light intensity from outside. There was a negative correlation between their characteristics. When the characteristic of carbon dioxide concentration was shifted forward by 1 hour with respect to the light intensity characteristic, the maximum value of correlation coefficient was obtained to be about -0.9. An integration value of a sensor output curve with time after the setting of potted plants could be regarded as a measure of an exposure volume of the plants to formaldehyde. The exposure value was found to become smaller as the number of the plants increased. In the experiment, formaldehyde was emitted continuously and the atmospheric concentration was kept at about 0.3ppm and the value was decreased to about 0.1ppm by the potted plants. This is close to the regulated value of 0.08ppm by WHO.
Malo više o samoj palmi na linkovima dole. Inače uopšte nije skupa i lepo izgleda :)
https://www.researchgate.net/public...ing_Formaldehyde_in_a_Real_Office_Environment
http://greener.rs/areca-palma/
Još malo o biljakama dobrim za vazduh
https://www.greenartns.rs/usluge.php?r=3027
https://www.mojenterijer.rs/feng-shui/feng-sui-biljke-koje-ciste-vazduh
P.S. Inače, sad gledam....Filteri na ipon.hu su 25-30e. Ne isplati se kupovati kod nas ni u ludilu. Samo uredjaji su isto 10-20% jeftiniji. U martu, taman kad istekne ovaj filter, idem po štek od 10ak komada. Još plus uvek možeš da se dogovoriš na količinu.
Samo da dodam da je Mi 3H koji sam kupio u BC groupu uvezen od strane Mi shopa, tako da ukoliko dodje do kvara moze da se reklamira direktno u Mi servisu.
Gde ima kod nas pro H model?
Послато са SM-G975F помоћу Тапатока
U mi-srbija online, a uskoro, nedelju dve dobijaju u radnji, kako mi ke prodavac rekao. Mene je mrzelo da cekam pa sam uzeo PRO
Hvala na potvrdi da nisam nigde pogresio :D pokusavao sam da ga dodam vise zbog robot usisivaca koji je stigao, na zalost izgleda da taj skill uopste ne radi... :( jos manje da se nadam da mogu da ga uparim sa homekit-om...
Nisam siguran da znam sta je skill, ali posto sam poprilicno u HomeKit-u, mogu da potvrdim da moze da se ubaci xiaomi preciscivac. Ja sam ubacio PRO, a vidim da ima plaginova i za druge modele i generalno za dosta xiaomi proizvoda.
Ubacuje se preko homebridge-a. Ako treba pomoc, tu sam.
Neka preporuka za air monitor sa Aliekspresa? Da bude sličnih karakteristika kao klimerko.
Moze mala pomoc u vezi odabira preciscivaca vazduha? Vidim da se uglavnom prica o Xiaomi 3H i Pro modelu i zanima me da li ima neka alternativa u tom cenovnom rangu? Isto tako, da li je toliko dobar da nema potrebe gledati bilo sta drugo? Razmisljam se da dodam jos malo i uzmem PRO model umesto 3H pa bi me zanimalo koji jos uredjaj je dobar u tom cenovnom rangu kako bih mogao da ih uporedim i napravim dobru kupovinu. Hvala!
Poručio PRO H model. Tražio sam da stigne u četvrtak, 10. decembra. Za sada šetam ovaj jedan gde god da idem. Malo mi je ćido da je filter pao na 98% za 2 dana, ali motriću na ovo.
Treba li da tražim fiskalni, ili je A4 račun sa pečatom dovoljan?
Hvala za preporuku za palme. Naručio sam juče tri komada za unutra, a usput još 6 biljčica za žardinjeru napolju. :D Ladno ima minijaturna kajsija, i to sam uzeo, živo me zanima da'l će da moći da se jede voće sledeće godine.
Tebi na kućnu donose? Jer si u BG vrv. Po Srbiji ne šalju, jer može da se smrzne, a u Subotici nema nigde na stanju jer se najveći lanac za trgovinu sadnica muči sa plastenikom. Mislim da ću morati i ja do BG-a. Inače ima Palma Arece u Ikea rasadniku, ali isto mora lično da se ide... NIje ni skupa preterano,i bolej deluje od ovih kvazi KP cvećara.
http://www.floraekspres.rs/
Što bi se smrzle, + je preko dana, a i noću u vozilu je sigurno +? Imaš ovde za ~1000 din malu od 60cm, koja će sledeće godine da bude metar (što sad prodaju za 3500+).
Naruči preko webshop pa vidi šta će da se desi.
Veruj mi pojma nisam imao za ovo! Vidim da ima plugin za sve i svasta, sto ce mi verovatno pomoci da skroz batalim Amazon i predjem na homepod mini.
Polusacu cim nadjem vremena i javiti ako zatreba pomoc za preciscivace :)
Hvala. Mada razmišljam da ipak uzmem velike, radi boljeg efekta fuktracije. Nisam stigao danas da pozovem, sutra ću. Bojim se da ne pošalju, pa da se smrzne.
Inače ovde pored jezera temp pada do -5 noću.
Evo i meni stigao 3H uzeo preko bcgrupe. Izmerilo 14 u kuci, cini mi se da je to dobro, videcemo kako ce biti kad bude zagadjeno napolju. Prva brzina se ne cuje dok druga i treca se bogami cuju. Povezao sa aplikacijom, sve radi super.
Sad je kosava u bgd.i vazduh je znatnk bolji.sad skoro da ne treba uopste..
Alo trebace.kad krene zagadjenje.pa jos kad nema vetra danima...
Ima li šta bolje od 3H za te novce?
Ne, realno.
Treba uzeti neki UV eliminator čestica, preći njime filtere jednom mesečno, jer ako nekoj bakteriji godi vlažnost i temp u filteru, može da se "zapati". Eto to je jedini add on što se može dokupiti... Tako mi reče šef danas :D
Ja ih držim na auto zbog formaldehida, nije sve u AQI ju :p
Šta je ovaj 3C?
Ispade novi model, a jeftiniji???
https://www.bcgroup-online.com/preciscivac-vazduha/xiaomi-mi-air-purifier-3c-eu-(bhr4518gl)-69638
Izgleda da je filter poboljšan, kao kod pri h modela i da traje 12 meseci..
https://smartme.pl/en/xiaomi-mi-air-purifier-3c-we-know-the-new-xiaomi-air-purifier/
Edit2: izgleda da je i 3c efikasniji, zato što uvlači vazduh i sa zadnje strane, dok se filter menja skidajući gornji deo uredjaja.
Povečana je površina na 106kvm, mda pipe da je da najoptimalnije da radi do 40(?!). 3H ima veču moč filtracije formaldehida.
Više na linku.
Tako da je pitanje da li je 3h zamena ili 2h zamena
https://www.mi.com/global/mi-air-purifier-3c
Ja sam bas razmisljao da uzmem neki za 15-ak dana i hteo sam pro h jer pokriva 60kvm koliki mi je stan i koliko sam skontao H je oznaka za unapredjeniju varijantu.
Ovaj 3c je maltene duplo jeftiniji a prociscava vecu povrsinu stana tj kvadraturu a ispade i da je filter bolji. U cemu je caka?
Sent from my SM-N770F using Tapatalk
Ispade na kraju sledeće, novi oled displej, novi, način ubacivanja filtera, poboljšan filter kompatibilan i sa 3h serijom. Slabiji od 3h serije po filtraciji i površini, tj zamena za 2 seriju / model izmedju 2 i 3h. Ima objašnjenje u mom prethodnom postu na zadnjem linku gde su svi modeli uporedjeni.
Edit: Evo slike poredjenja u prilogu, da se lakše vidi
    515.8 KB · Pregleda: 259
Nije zamena za 3h, nego za 2 seriju. Vidi se gore na slici. Slabiji je od 3h već apslovirano.
Sad xiaomi izgleda drugačije formuliše površinu prečišćavanja, tako da 3c ima 106kvm, dok 3h 126kvm (a inicijalno je bio reklamiran kao do 48skm što i jeste tako, dok je za 3c do 40kvm)
Marketing je čudo
Ako ima neko model 3C... Da li Xiaomi 3C meri temperaturu i vlažnost, kao ostali modeli?
ako imaš 60 kvadrata bez ikakvih pregradnih zidova onda može, ali neće ti to pokriti čitav stan ako imaš odvojene sobe...ne može on tako da pročisti vazduh u čitavom stanu koji ima izdvojene prostorije...
Poruci 3H u bc group za 17.500 sa onim kodom kp5. Pristojna cena. Ukoliko neko planira da kupi, pri porudzbini samo stavite gotovinsko placanje da dobijete dodatnih 10% i u promo kod ukucajte kp5 i to je nekih dodatnih 900 dinara popusta. Ja sam narucio neulogivan.
Ima li neko preporuku za ovlazivac vazduha?
Pisao sam ovima iz xiaomi-ja da vidim kako da sprecim da ovlazivac aktivira preciscivac ali niko mi nije odgovorio.
Sve što oslobađa čestice u vazduh prečistač detektuje, da li je to humidifajer ili npr. otvoren kamin on ne pravi razliku.
Pomoći nema.
I ja sam trenutno u potrazi za ovlazivacem, mada cu verovatno uzeti neki od 1000rsd, dok ne uzmem iz kine xiaomi neki.
Za aktiviranje preciscavaca tek treba da proverim, mada mislim da je to problem koji se javlja samo na pocetku prskanja. Kada postigne i pocne da odrzava vlagu, pretpostavljam da ce manje da prska, a samim tim i da ne remeti preciscavac. Takodje bih rekao da postavljanje na vecu visinu moze da pomogne, svakako sto dalje to bolje.
Marketing je čudo
Ne bi me iznenadilo da su hteli da kažu da 3H pročišćava 126 metara kubnih na čas, što je i logičnija merna jedinica, jer on ne čisti pod nego pročišćava vazduh, pa je bitnija zapremina nego površina. Nije svejedno da li je reč o standardnoj sobi površine 20 kvadrata i visine 2,4 m ili sobi iste površine u salonskom stanu visine 3,5 m. Kad onih 126 podeliš sa 48 kvadrata dobijaš oko 2,6 m visine, što su možda uzeli kao neki prosek.
Pozdrav. Skoro sam uzeo xiaomi mi air purifier 2H. Da li postoji mogućnost da na aplikaciji Mi Home očitava vrednosti u realnom vremenu? Da bi osvežio merenje, moram da izađem iz aplikacije pa da ponovo uđem,što je iritantno. Aplikacija je apdejtovana verzija 5.8.7 i nisam našao neka podešavanja u tom smislu. Ima li nekog rešenja?
