Galaxy Ace - internal phone storage space is nearly full
Pablo
Imam problem sa Galaxy Ace telefonom i internom memorijom. Cim slobodno mesto na internoj memoriji padne na ispod 18 MB dobijem poruku: "Internal phone storage space is nearly full unistall some aplications to free bla bla bla"
A ako neoslobodim mesto nemogu ni obican sms da primim shto mu dodje kao da onih 18mb uopste nemogu da koristim. Phone mi je rootovan i sve aplikacije sam prebacio na SD karticu pomocu App Manager Pro i na internoj memoriji mi se nalaze samo widgeti i to: 111 Meni / Battery Monitor / Go Weather / Launcher Pro / Lookout / My Data Manager i Where's My Droid.
Neshto sam googlao i naisao sam na ovo:
http://androidforums.com/htc-hero/91599-low-space-notification-doesnt-go-away.html
*** Solution for rooted devices ***
Hi there,
I'm new here and I had this problem until yesterday. I read a lot of solutions in Internet, like cleaning delvik-cache (thtat will be recreated at next start-up), cleaning apps caches, but nothing worked, I still had just 18 MB free!!
I've decided to explore /data partition with linux "du" command and surprise, there was 14 MB in "/data/local/tmp", and like its name suggest, these are Temporary files!!. Now I have 30 Mb free space!
Solution with ADB:
Kod:
# adb shell
# cd /data/local/tmp
# rm *
I think this tmp files weren't deleted because I use to use "Advanced Task Killer".
I wish you luck with this procedure.
Esteban
Shta josh moram da instaliram pored ADB-a nek mogu da probam da odradim ovo shto je lik napisao i shta josh pored ovog mogu obrisem da dobijem na prostoru ??
ako ti je telefon rooted i imas custom recovery (clockworkmod) odes u recovery i izaberes wipe dalvik cache
Phone mi je rootovan ali nemam flashnut costum recovery. Ako nishta neuradim sa onim upustvom shto sam nasao na netu flashovacu taj costum recovery...
to ti je najbolje resenje, imas na xda uputstvo bezbolno je. btw treba vremenom cistiti taj dalvik cache, jer kako upgradujes neku app cache ostaje od starih verzija. posle ciscenja ide malo duzi boot jer tada kreira nov cache od samo instaliranih apps u telefonu.
Instalirao sam Clockworkmod 4.0.0.9
Pratio sam ovo upustvo:
http://forum.xda-developers.com/showpost.php?p=18625602&postcount=27
A sort of workaroud could be this:
- Get Superuser
- Don't install the Rom Manager
- Download the ClockWork Recovery version 4.0.0.9 from here: multiupload.com/ERQ85J3YQ8
- Copy that file on sd
- Reboot in recovery mode (HOME + POWER)
- Install that file (this should install the ClockWork Recovery)
Ovo sam sve odradio a ovo mi nije jasno i ovo nisam odradio ali imam clockworkmod recovery:
- Reboot and copy on sd the CM7 file
- Reboot in recovey (this time is the clockwork one)
- Install... Taadaaaa
Shta sa ove tri stavke ???
EDIT: Obrisao sam dalvik cache i dobio sam nekih 7.5MB :)
^^Skontao sam :D
One tri stavke su za flashovanje drugog ROM-a :D
Hvala za ovo, pokusacu i ja to da uradim. :)
Mene recimo iritira to sto telefon potpuno ignorise podesavanje da podatke salje na sd i ext particiju vec sve siba na internu memoriju pa moram rucno da pomeram.
Custom rom je u pitanju, ali ni na drugim romovima nije bilo drugacije.
A jel' bezbedno nekim od file explorera ući u folder dalvik-cache i onako ručno izbrisati sve ili mora iz Titanium Backup-a ili sličnog programa to raditi? Koliko sam ja skontao, TB samo pretraži da li ima neki fajl koji ne pripada nijednoj instaliranoj aplikaciji i njega briše, a možda ne bi bilo zgoreg pobrisati dalvik cache i instaliranih aplikacija, ko zna kakvo se "đubre" od njih tu zapati :)? Neću ništa da zeznem ako to odradim?
Ok sad kad sam flashovao clockworkmod 5.0.2.6 mislim da stavim neki costum ROM. Mislio sam da stavim CyanogenMod 7.2-cooper-KANG-RC0-Android 2.3.7
Sad kako preko clockworkmoda da ga flashujem ? Jel idem na apply sdcard: update.zip ili na instal zip from sdcard ?
Nema veze flashovao sam :D Juce sam ceo dan kopao po xda i dosta toga sam pokupio...
Flashovao sam CyanogenMod 7.2 cooper KANG RC0 Android 2.3.7 by J.A.F. i telefon se preporodio. Nemogu da verujem koliko brze radi u odnosu na stock samsung rom koji je pun bloatware-a i koliko vishe slobodnog mesta imam na internoj memoriji. SD karticu od 8Gb ( Class 10 ) sam podelio na tri particije:
  • 64MB linux-swap
  • 1024MB ext4
  • 6.44GB fat32
i sve aplikacije koje nekoristim cesto sibam na karticu a pomocu s2e aplikacije i sav cache sam stavio na karticu. App data sam ostavio na internoj memoriji.
Sad nekuburim sa slobodnim mestom na internoj memoriji... ...a i imam brdo slobodne RAM memorije;
Probaj ovo shto sam ja odradio. Mada ja u CyanogenMod settings mogu da biram gde da mi phone po defaultu instalira aplikacije.
Fino deluje taj rom, svaka cast na tolikoj slobodnoj memoriji. :)
Hvala, ne brljavi mi vise otkad sam podesio Cyanogen kako valja i rucno ispremestao sporne aplikacije na SD.
Elem, ja koristim odlican rom http://forum.xda-developers.com/showthread.php?t=1324628 koji je prilicno kul zbog brzine rada i fensi izgleda po ugledu na Xperia Arc (SE fontovi, boje i efekti).
Evo par shotova, memorije sasvim dovoljno:
