xwave 3100 problem
danijel07
Cenjen
dakle problem je sledeci.skidao sam brdo BRripova i danas kupim ovaj plejer kad ono nista od toga nece da cita.da li mozda treba da ih konvertujem ili neka nadogradnja softwera na plejeru????
Ti Brripovi su radjeni sa x264om (daj mediainfo nekog fajla da vidimo - posto nikad nisam gledao iste)...
A tvoj player podrzava jedino Mpeg4 asp odnsono xvid/divx
Najbolje ubaci neki brrip u media info, epxortuj txt i kopiraj ovde pa cemo ti reci kako i cime da konvertujes.
General
Complete name : C:\Users\Danijel\Downloads\RED 2010 BRRip 720p H264-3Li\RED.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 2.18 GiB
Duration : 1h 51mn
Overall bit rate : 2 805 Kbps
Encoded date : UTC 2011-01-08 20:23:11
Tagged date : UTC 2011-01-08 20:23:11
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 1h 51mn
Bit rate mode : Variable
Bit rate : 2 404 Kbps
Maximum bit rate : 16.4 Mbps
Width : 1 280 pixels
Height : 528 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.148
Stream size : 1.86 GiB (86%)
Title : RED By 3Li
Writing library : x264 core 98 r1649 c54c47d
Encoding settings : cabac=1 / ref=8 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=0.81:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / constrained_intra=0 / bframes=4 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=2404 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Tagged date : UTC 2011-01-08 20:24:39
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 1h 51mn
Bit rate : 402 Kbps
Maximum bit rate : 418 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 319 MiB (14%)
Title : RED
Language : English
Encoded date : UTC 2011-01-08 20:24:25
Ti filmovi su radjeni x264 odnosno to su H264 filmovi.Takve player nece citati
Mora reencoding u xvid/divx.
Ali sa danasnjim brzinama brze ces skinuti isti taj film xvid nego da konvertujes brripove plus ce i kvalitet biti bolji
NO ako bas oces onda imas mnogo mogucnsti
VirtualDub
Megui
Avidemux
Mada tebi posto si verovatno pocetnik u ovome Super(iako je najlosiji ) bice najlakse resenje ili AutoGK
Imam isti plejer i prezadovoljan sam kako obavlja ono sto je propisano ali, kao sto weasel kaze, on nema mogucnost reprodukovanja x264/h264 filmova i ogranicen je na mogucnosti cipa MTK1389. Sto se tice softverskih nadgradnji postoji programcic MTK ReMaker ali i pomocu njega neces povecati funkcionalnost odnosno mogucnosti plejera nego samo mozes da unapredis interfejs estetski (da promenis slicice, ubacis lepse fontove za titlove itd...).
Ako imas TV vece dijagonale sa digitalnim ulazom, povezi ga direktno sa racunarom i uzivaj, a ako imas klasican (CRT) televizor, veruj mi da nista veliko neces dobiti pustajuci film od 1080p na 576p ekranu. Skidaj obicne divx filmove u avi formatu i gledaj. Veruj mi, izgledaju vise nego dobro, bolje nego na monitoru. 🙂
Hvala puno na odgovoru. Poslusacu tvoj savet i pocinjem iste da skidam u divx-u,pozz!
Hvala na savetu,a gde da nadjem taj program mtk remaker?pozz
Možete li pomoći meni. Naime, otkazao mi je daljinski za DVD Xwave 3100. Hteo bih da probam sa nekim univerzalnim ali nigde ne mogu naći kod. Zna li neko?
