XSPC Rasa 750 RX240 WaterCooling Kit
jer moze ovo da se nabavi kod nas i kako.
Jer neko probao ovaj kit.
This kit is ideal as a simple CPU watercooling kit and removes more heat than air cooling.
The kit is designed to be quiet and also handle overclocked CPU's. The pump is strong enough that other waterblocks can be added to the loop if required.
Please Note : Fluid is not included with this kit but can be found HERE
Model
Manufacturer XSPC
Model Number Rasa 750 RX240
Specification
Intel Socket Compatibility Socket 1366
Socket 1156
Socket 1155
Socket 775
Socket 604
Socket 603
AMD Socket Compatibility Socket AM3
Socket AM2+
Socket AM2
Socket 940
Socket 939
Socket 754
CPU Waterblock XSPC Rasa Black
VGA Waterblock N/A
Radiator XSPC RX240
Radiator Dimensions 286 x 125 x 58.5mm
Radiator Fan Specification 2 x Low Noise 1700rpm 120mm Fan
Pump XSPC X20 750 12v
Pump Flow Rate 750 L/ph
Reservoir Built In Pump
Tubing 7/16" ID - 5/8" OD Clear
Fittings 6 x 1/4" thread 1/2" Barbs
Fluid Not Included
Suitability Simple CPU Watercooling
Overclocking
Package Contents 1 x XSPC Rasa Black CPU Waterblock
1 x XSPC RX240 Radiator
1 x CPU Backplate for 1366, 1156, 1155, 775
2 x 120mm Fan
1 x XSPC X20 750 Pump & Reservoir combo
2 x 7/16" Clear Tubing
6 x 1/2" Barb Fittings
1 x 5mm Blue LED
1 x Velcro Mounting Pad for Pump
6 x Hose Clips
1 x 80 - 120mm Radiator Mounting Kit
1 x Thermal Paste
1 x CPU Mounting Kit
XSPC-Rasa-750-RX240-WaterCooling-Kit-pid-12933.html
hvala.
