Posto ovaj post nema veze sa Veratom gde sam postovao napravio sam novi topic. Sve predloge postujte ovde
Zivim u Loznici. Do sada nisam imao nikakvih problema ali mi pre mozda mesec dana wireless poceo da usporava i da gubim dosta paketa. Jacina signala mi je dobra ali ima dosta paketa koje ne primim. Ovo mi se desavalo postepeno. Sada imam nekih 30% propustenih pakete. Posto dosta igram World of Warcraft ovo je nepodnosljivo. Sporije surfujem a nekada nece ni web stranice da mi otvor. Ima li ko ideju sta je moglo da se pogorsa toliko. Inace duzina izmedju antene i AP je 2km. Signal je jak sto su mi i oni potvrdili ali iz nekog razloga gubim dosta podataka.
Ping statistics for 66.249.93.104:
Packets: Sent = 138, Received = 101, Lost = 37 (26% loss),
Approximate round trip times in milli-seconds:
Minimum = 52ms, Maximum = 582ms, Average = 156ms
Reply from 66.249.93.104: bytes=32 time=72ms TTL=238
Reply from 66.249.93.104: bytes=32 time=62ms TTL=239
Reply from 66.249.93.104: bytes=32 time=205ms TTL=239
Reply from 66.249.93.104: bytes=32 time=97ms TTL=238
Reply from 66.249.93.104: bytes=32 time=63ms TTL=238
Request timed out.
Request timed out.
Request timed out.
Reply from 66.249.93.104: bytes=32 time=68ms TTL=239
Reply from 66.249.93.104: bytes=32 time=120ms TTL=238
Reply from 66.249.93.104: bytes=32 time=211ms TTL=238
Reply from 66.249.93.104: bytes=32 time=67ms TTL=239
Reply from 66.249.93.104: bytes=32 time=115ms TTL=239
Request timed out.
Request timed out.
Reply from 66.249.93.104: bytes=32 time=87ms TTL=239
Reply from 66.249.93.104: bytes=32 time=58ms TTL=239
Reply from 66.249.93.104: bytes=32 time=56ms TTL=238
Request timed out.
Request timed out.
Opticka vidljivost mi odlicna nema nikakvih prepreka. Brzina veze mi je 128 kb/s. Zvao sam i providera ( inffo net ) mada oni kazu da je kod njih sve u redu i jacina signala odlicna.
Ako ko ima neki savet i pitanja ja cu vam odgovoriti sto je pre moguce. Unapred hvala.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
