Warlords cheats
Lucas
jel postoje neke sifre za warlords?
(ortak se pravi vazan, a ima neke lude heroje...)
Pa kad bih mogao da moje tri jedinice malkice osnazim. (one sto prenosim iz borbe u borbu)
Recimo sve special abilities na +5 (manje vise vec jesu na +5...)
Plus helth i damage da povecam za 10-20... ;)
*trazio sam na ~10-tak sajtova na netu, ali nigde nema niceg...
pa ako neko ima ideju...
i da, koji su najjaci domaci forumi za igre?
Warlords 3
Burn down all sites burn baby burn
Water turns green not easy being green
All units and production turn into Tanks just for grant
All units get medal purple heart
Upgrade cities to Citadels +3 king of the castle
All units turn into dragons dragon rush
99 movement for all units run spot run
1000 experience for selected hero there can be only one
Full map but now i can see
Remove fog of war on a clear day
20 Mana show me the mana
Conquer all cities i am lazy
Hero stats set to S:9, H:4, L:5, M:50 call me conan
10,000 money if i were a rich man
New Background Music name that tune
Cities not getting mana get 1 per turn lord of the mana
Production time of every unit set to 1 hiho hiho
Warlords 3 - Darklords Rising
Press F8 during play and type in the following codes:
Cheat Code Result
JUST FOR GRANT - all your creatures become 9/4 tanks,
and take only 5 turns to produce
NAME THAT SONG - soundtrack changes to a different song
TOUGH BEING GREEN - changes water color to green
Hints:
If you play the Bane's Revenge campaign, you'll quickly find
that the victory conditions of the first scenario are deceptive.
Your goal is not only to hold as many rooms of the castle as
possible; there's one room in particular that will grant victory
to the side that holds it for ten turns.
In some scenarios, the enemy heroes will start out with significant
advantages (especially the distance they can move per turn).
This allows them to explore a larger number of Ruins, so compensate
by questing early and often. Make sure you undertake quests that are
of easy or average difficulty; these types of quests can be completed
quickly.
Pillaging an enemy castle is your best bet (unless you're on a quest
that specifically demands that you do otherwise). This is especially
true if it's a castle in which the enemy has invested a great deal of
gold for production of units.
zaboravio sam da napisem za koj warlodrs :(
warlords IV Heroes of Etheria
