'vako:
Win2000, SP2 nije na mrezi ima samo dial up.
iskljucio sam disk counter preformance [diskperf -n]
iskljucen je Server servis kao i ostali koji mi ne trebaju sad kada mi racunar nije na LAN-u. Sada mi u App. logu stalno
prijavljuje dva errora pri svakom boot-u:
Source: PerfDisk
Desc: Unable to read the disk performance information from the system. Disk performance counters must be enabled for at least one physical disk or logical volume in order for these counters to appear. Disk performance counters can be enabled by using the Hardware Device Manager property pages. Status code returned is data DWORD 0.
Source: PerfNet
Desc: Unable to open the Server service. Server performance data will not be returned. Error code returned is in data DWORD 0.
u Performance Logs & Alerts sam sve iskljucio i svuda zivo sam gledao ukljucujuci i registry search za karakteristicne reci koje se pominju i nigde nista.
Kako da ubijem Perf* sra*e?
hvala unapred
Source: PerfDisk
Source: PerfNet
hvala unapred
