Danas je počeo komp malo da mi brlja, jako sporo otvara programe, dolazi do kočenja svega na momente. Koristim XP SP2 i Zone Alarm. Zabrinut šta se to dešava, reših da pogledam šta se događa u task manageru, kad ono vsmon.exe mi jede 99% CPU. Odem na microsoft-ov sajt, ukucam u pretragu vsmon.exe i dobijem sledeći savet:
PRB: Firewall software may cause a Visual Studio .NET installation to stop responding (hang)
View products that this article applies to.
This article was previously published under Q321434
Important This article contains information about modifying the registry. Before you modify the registry, make sure to back it up and make sure that you understand how to restore the registry if a problem occurs. For information about how to back up, restore, and edit the registry, click the following article number to view the article in the Microsoft Knowledge Base:
256986 Description of the Microsoft Windows Registry
SUMMARY
When you install Microsoft Visual Studio .NET on a computer that uses third-party firewall software, such as Zone Labs ZoneAlarm Pro, the Microsoft Windows Component Update (WCU) does not install all the Microsoft .NET Framework components, and the installation may stop responding (hang).
SYMPTOMS
When you install Microsoft Visual Studio .NET programs, the WCU does not install all the Microsoft .NET Framework components. The WCU installation may stop responding while it is installing the Microsoft .NET Framework.
CAUSE
If you use third-party firewall software, such as ZoneAlarm Pro, the firewall software may prevent some Microsoft Internet Information Services (IIS) services from starting correctly. This prevents the WCU from installing all the Microsoft .NET Framework components.
RESOLUTION
Warning If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk.
To resolve the problem of ZoneAlarm Pro firewall software, use the following methods:
Add a new registry subkey that is named W3SVC.
Turn off the firewall service.
On a computer that is running Microsoft Windows NT or later, use Registry Editor.
Locate HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\vsmon.
Note Vsmon is a service that is installed by ZoneAlarm Pro.
In the right pane, double-click DependOnService.
In the Edit Multi-String dialog box, you will see a list of items that might include Afd, RpcSs, and Vsdatant. Add W3SVC to the end of this list, and then click OK.
Quit Registry Editor, and then restart the computer.
On a computer that is running Microsoft Windows XP or Microsoft Windows Server 2003
Click Start, click Run, type MSConfig.exe, and then click OK.
In the System Configuration Utility dialog box, on the General tab, click Selective Startup.
Click to clear all check boxes under Selective Startup.
Click the Services tab, and then click to select the Hide All Microsoft Services check box.
Note The services that are not related to Microsoft and that are running on the computer are listed.
Click to clear all check boxes.
Click the Startup tab, and then click to clear all firewall check boxes and all antivirus program check boxes.
Click Apply, and then click OK.
Restart the computer after you receive a message to restart.
Note After you install Visual Studio .NET, start the MSConfig.exe utility, select all check boxes that you cleared to resolve this problem, and then restart the computer.
On a computer that is running Microsoft Windows 2000
Click Start, point to Settings, and then click Control Panel.
In Control Panel, double-click Administrative Tools.
In the Administrative Tools window, double-click Services.
In the Services snap-in, disable the firewall service that is running:
Right-click the firewall service, and then click Properties. The properties dialog box of the firewall service appears.
On the General tab, set the Startup type to Disabled.
Restart the computer.
Note If you turn off the services, you must manually turn them on again after you install Visual Studio .NET.
For information about what to do if you have third-party firewall software other than ZoneAlarm Pro installed on your computer, see the "More information" section.
MORE INFORMATION
This problem occurs with many third-party firewall products. The firewall software may interfere with some IIS services. If you view the IIS services by using the Service Manager, you may notice that some IIS services, such as the World Wide Web Publishing service, the FTP Publish service, and the Simple Mail Transfer Protocol (SMTP) service, are in "Starting" status instead of in "Started" status. You may also notice that some IIS services never start while the firewall software is running.
This problem also affects Symantec Proxy Service. For more information, visit the following Symantec Web site:
http://service1.symantec.com/SUPPOR...902dc354165ac3d188256b6600763722?OpenDocument
When you install Microsoft Visual Studio .NET programs, the .NET Framework tries to stop all IIS services. If the IIS services never enter the "Started" status, the installation process will stop responding.
Your firewall software provider may have an update to resolve this problem. We recommend that you contact your software provider for updates to your firewall software.
The third-party products that this article discusses are manufactured by companies that are independent of Microsoft. Microsoft makes no warranty, implied or otherwise, regarding the performance or reliability of these products.
The information in this article applies to:
Microsoft Visual Studio .NET (2003), Professional Edition
Microsoft Visual Studio .NET (2003), Enterprise Architect Edition
Microsoft Visual Studio .NET (2003), Enterprise Developer Edition
Microsoft Visual Studio .NET (2003), Academic Edition
Microsoft Visual Studio .NET (2002), Professional Edition
Microsoft Visual Studio .NET (2002), Enterprise Architect Edition
Microsoft Visual Studio .NET (2002), Enterprise Developer Edition
Microsoft Visual Studio .NET (2002), Academic Edition
Microsoft Visual C++ .NET (2003)
Microsoft Visual C++ .NET (2002)
Microsoft Visual Basic .NET (2003)
Microsoft Visual Basic .NET (2002)
Microsoft Visual C# .NET (2003)
Microsoft Visual C# .NET (2002)
Microsoft Visual J# .NET (2003)
Microsoft Visual J# .NET (2002)
Last Reviewed: 6/11/2004 (5.0)
Keywords: kbprb kbsetup KB321434
Treba mi vaš savet, šta da radim. Da činim kao što oni rekoše ili ima neki bolji način za rešenje ovog problema. Inače, takođe sam primetio da mi se na par sekundi gubi slika sa monitora. I to je počelo danas. Komp mi je uključen skoro non stop...
SUMMARY
SYMPTOMS
CAUSE
RESOLUTION
MORE INFORMATION
