Vista 32bit ultimet
pa pazi
ako to pise na Microsoft sajtu ja bih mozda rekao da je istina...mada ta tvoja Vista 32bit ultimet mozda poznaje vise memorije jer je nema u tabeli :D
pa pazi
Greska umesto Vista 32bit ultimet treba Windows Vista 62bit Ultimate
ajde treca sreca - mozda i ubodes
Windows Vista 32bit Ultimate
Steka mi nesto tastatura :type:
Bravo kralju, cuti kad ima neko i da unosi malo humora na ovom forumu.:D
P.S. Ja se utripova kad sam video thread reko sta je ovo neka nova verzija viste za "napredne korisnike"! Kad ono ultimet 62bit-a:D
sad po 101. put
teoretski maximum i za vistu i za xp odnosno za 32 bitne sisteme je 4 gb
ali to NIKAKO NE znaci da ces tebi videti 4 gb u praxi je to 3.2 3.0 3.1 ....
ja se izvinjavam ali 32bitni sistemi:
Windows Server 2003 SP2, Datacenter Edition 128 GB/64 GB with 4GT
Windows Server 2003 SP2, Enterprise Edition 64 GB
Windows Storage Server 2003, Enterprise Edition 8 GB
Windows XP Professional and Windows Server 2003 Memory Support. The maximum amount of memory that can be supported on Windows XP Professional and Windows Server 2003 is also 4 GB. However, Windows Server 2003, Enterprise Edition supports 32 GB of physical RAM and Windows Server 2003, Datacenter Edition supports 64 GB of physical RAM using the PAE feature.
The virtual address space of processes and applications is still limited to 2 GB unless the /3GB switch is used in the Boot.ini file. When the physical RAM in the system exceeds 16 GB and the /3GB switch is used, the operating system will ignore the additional RAM until the /3GB switch is removed. This is because of the increased size of the kernel required to support more Page Table Entries. The assumption is made that the administrator would rather not lose the /3GB functionality silently and automatically; therefore, this requires the administrator to explicitly change this setting.
The /3GB switch allocates 3 GB of virtual address space to an application that uses IMAGE_FILE_LARGE_ADDRESS_AWARE in the process header. This switch allows applications to address 1 GB of additional virtual address space above 2 GB.
The virtual address space of processes and applications is still limited to 2 GB, unless the /3GB switch is used in the Boot.ini file. The following example shows how to add the /3GB parameter in the Boot.ini file to enable application memory tuning.
http://www.microsoft.com/whdc/system/platform/server/PAE/PAEmem.mspx
http://www.microsoft.com/whdc/system/platform/server/PAE/pae_os.mspx
