visa basic crcdisk.sys problem
gogi100
imam msi laptop na kome je instalirana vista basic. skoro sam dobio adsl i surfovao internetom. jutros kad sam ukljucio laptop vista pokusava da se bootuje,ali nista. pokusao sam sa F8 da udjem u safemode medjutim kad pocne sa ucitavanjem drajvera dodje do crcdisk.sys i ne mrda. ostale opcije iz F8 ne rade. Mozete li mi predloziti sta da radim. Da li vredi pousavati sa
Kod:
1) I start windows Vista from my DVD and select repair, select the command to star the console.
2) in the command promt I go to where my windows is installed and remane ( or delete) the followind file:
\windows\system32\drivers\pcmcia.sys*
\windows\system32\drivers\1394bus.sys
\windows\system32\drivers\ohci1394.sys
\windows\system32\driverstore\filerepository\pcmcia.infblablabla*
\windows\system32\driverstore\filerepository\1394.infblablabla
\windows\system32\driverstore\filerepository\sdbus.infblablabla*
\windows\inf\sdbus.inf*
\windows\inf\sdbus.PNF*
*NOTE: the file with * where NOT renamed (or delete) and it worked for me. In case Ur PC freeze again try to rename all files.
3) exit and restart.
Hvala
