"veliki" problem sa MSN-om...
rossi-old
Naime ne mogu nikako da se ulogujem,non stop mi izbacuje greshku
Error code:80048820
Extended error code:80048412
to mi se deshavalo na XP-u poslednjih 10 dana i nisam uspeo da reshim,pokushao sam da obrishem programce i opet instalirao i corak...
Evo sad instalirao Vistu i opet nishta,tacnije ne radi,ne mogu da verujem...
Inace koristim Windows Live messenger,mislim 8.0
Ajde pomozite molim vas...:wave:
MSN Messenger Error Code - 80048820Error Code 80048820 MSN Messenger
The Symptoms you get
When you try and launch MSN Messenger and try to logon, you get an error message 80048820. A wild guess, your system time / date needs adjusting.
The Cause of Code 80048820
There are a variety of causes of this error:
1) Incorrect Proxy Setting for Internet Explorer.
2) softpub.dll may have become unregistered.
3) Your system clock may be showing an incorrect time (or date!).
4) Firewall problems.
The Solutions to MSN Error Code 80048820The Solutions to MSN error code80048820
Internet Explorer - Try removing Internet Explorer proxy server settings and go with the 'Automatically detect settings'.
1) Launch Internet Explorer, click Tools and then click Internet Options.
From the Internet Options dialog box, go to the Connections tab.
Click LAN Setting. Un check the Use a proxy server for your LAN (These settings will not apply to dial-up or VPN connections) checkbox. Finally positively tick: 'Automatically detect settings'.
2) Register softpub.dll.
Click Start (Button), and then click Run, type regsvr32 softpub.dll. Restart MSN Messenger. See also Error code 81000314
3) If necessary, logon as a local administrator, set the computer's clock to the correct date and time. (Check on the internet if possible.)
4) Turn off the firewall temporarily. Check firewall settings such as Norton: "Block access to secure sites". If this cures the problem, make sure that Microsoft's MSN Messenger is allowed full access through your firewall.
NetGear problem
a) Enter IP address 192.168.0.1 in the IE address bar.
b) Log on with ISP user name and password.
c) Enter Admin, password
d) Navigate to advanced menu, WAN set-up
e) Change MTU size to 1400
5) Try a password of no more than 8 characters.
6) If you are using IE 7.0 check the SSL Settings. Internet options advanced (Tab) scroll down to the bottom. Security section. Tick 'Use ssl 2.0'.
6) Drastic! Try uninstalling MSN Messenger version 7.5 and install Microsoft MSN version 7.0.
Summary of MSN Error Code 80048820
If you are suffering from MSN Error Code 80048820, check your system clock. If both time and date are correct, try turning off your firewall.
Ako ne pomogne, ima na Googlu tona o tome... :eyebrows:
jutros je proradio sam od sebe...
A 10 dana nije hteo,cudo je ova Vista,hvala puno u svakom slucaju🙂
Mozda je bilo do provajdera i ne vidim sta je ovde tako VELIKO
veliko je to shto imam 50 kontakata,pola njih iz inostranstva a 10 dana ne mogu da stupim u kontakt sa njima...
