VBulletin 2.2.6
Majstore... Hvala Bogu da su moje reči o poenti WareZa bar do nekoga doprle(kakav izraz)
BRAVO JOŠ JEDNOM CARE!(D)
Wakizashi je napisao(la):
Xe xe xe,
pa valjda si primetio u zadnje vreme da cim naletim na nesto interesantno postujem to i ovde ;)
Skinuo sam i podigao u lokalu. Stvarno lepa "srkiptica" :) lepo radi.
Zahvaljujem.
dobio sam email
LEGAL RESEARCH ASSOCIATES, LP
P.O. Box 11133
Bakersfield, CA 93389-1133
(661) 832-5757 E-mail: [email protected]
May 30, 2002
Re: vBulletin Software Licensing at http://www.pdf.org.yu/forum/
Gentlemen:
We are the Internet Copyright Enforcement agents for Jelsoft Enterprises, LTD, the publishers of vBulletin software.
It has come to our attention that you are using vBulletin software to operate the forum on your website, and we were unable to locate a valid license in Jelsoft's database authorizing your use of the software.
If you believe that your web site has a valid license to use vBulletin software, please promptly contact [email protected] and provide your licensing information so that Jelsoft's records may be corrected.
PLEASE NOTE: If you own a valid license and failed to register the URL where the software is in use at the "member" section of the vbulletin.com website (as is required by the license agreement), your site may appear to be "unlicensed" in the database.
If you are unable to provide evidence of a valid site license and desire to continue using vBulletin, you are requested to purchase or lease a license to use vBulletin software at: http://www.pdf.org.yu/forum/
vBulletin licenses may be purchased on-line: http://www.digibuy.com/cgi-bin/order.html?vbulletin
within TEN (10) days from the date of this Notice.
OR
Immediately Cease and Desist from using vBulletin software at the web site(s)/domain(s) referenced above. Continued unlicensed use of vBulletin software will be construed as intentional infringement of the lawful copyrights of our client and we will be forced to take appropriate action to ensure compliance with the law.
vBulletin Order Options
Leased License - $85
A leased license grants you the right to run vBulletin on one web server and one web site for each license purchased for 1 year from date of order. Each license may power one instance of vBulletin on one domain. During the year, you will have unlimited access to the member area, where you can download updated versions of the software. At the end of the year, you must purchase another license in order to continue to run vBulletin.
Owned License - $160
An owned license grants you the right to run on one web server and one web site for each license purchased for an unlimited time. Each license may power one instance of vBulletin on one domain. Included in this package is one year's access to the member area, where you can download updated versions of the software. If you require access to the member area after the year has elapsed, you can renew your access for $30 per year.
For more information about vBulletin licenses, please email [email protected].
By purchasing this software, you agree to adhere to the license agreement.
Your cooperation and assistance in this matter would be most appreciated.
Regards,
Michael P. Watso
Copyright Enforcement Agent
Ne znam sta da ti kazem. To isto se dogodilo i Benchmark -u. Platio se jednogodisnji ugovor. Nisam siguran sta mogu da tebi urade direktno, pre jedno godinu dana nista, a sada ne znam. Verovatno najgore sto mogu da urade je da pozovu Verat.net i da traze da se forum obrise. Ako imamo nekog pravnika ovde koji je upoznat sa tematikom nek napise njegovo misljenje.
Jedan nas poznat sajt koji drzi rom -ove za emulatore je imao takvo iskustvo, isto sajt na Verat -u i pobrisali su mu problematicne fajlove.
Inace svidja mi se kako su se pretstavili: "Internet Copyright Enforcement agents". Pazi samo da ti se ne pojavi Agent Smith umesto nekog od ukucana :)
Mozda da saznas kakva su iskustva drugih ljudi u slicnoj situaciji.
Nista, uglavanom pisi sta se desava.
Imam jedan predlog, mada si sigurno o njemu razmisljao. Zasto ne predjes na neki od besplatinih alternativnih forum -a. Dosta njih je stasalo do sada, rade verovatno stabilno a i onako im je uzor bio vbulletin tako da uz malo promene grafike i tweak -inga mozes dovesti izgled da bude identican vbulletin -u. Pogledaj ovu stranu:
http://www.spoono.com/codebase/php/?link=Bulletin Boards
a moja preporuka je:
http://www.phpbb.com/downloads.php ili
http://www.xmbforum.com/
A najbolje od svega je sto nude konvertore vbulletin baze pa mozes da zadrzis sve thread -ove i member -e. Za to sam siguran da ima phpbb, za ovaj drugi ne znam.
I da oba rade u PHP MySql kombinaciji.
Pozdrav i srecno!!!
