http://www.guru3d.com/newsitem.php?id=3246
Here are some of the details he provided:
- minimum: 2.8GHz, 512mb Ram,Geforce6
- for high details: 3-4GHz, 1Gb Ram, Nvidia 6800GT/ultra or 7800GT/GTX SLI
- Dual-core Processor use: Multi-Threading is supported and should provide much better performance.
- 64 Bit version available with better textures
- Renderers: Shader-3.0, Fallback-Mode for Shader 2.0 maybe a dx8 renderer.
- HDR: yes
- physics: Novodex-Physik-Engine.
- Ageias PhysX Processor supported.
- HDR: yes
