ubuntu resolution problem
illidan
Nenadmašan
CPU & Cooler
amd 5800x3d, ek nucleus cr240 dark - phanteks t30
Matična ploča
asus rog strix b550-i gaming
RAM
g.skill trident z neo 32gb cl16
GPU
nvidia rtx 4070super founders edition
Storage
samsung 980 pro 1tb, wd black sn770 2tb
Zvuk
ifi zen dac v2 - s.m.s.l ao200 mk2 - kef q350, fiio ft1 balanced
PSU
corsair sf750 platinum
Kućište
lian li a4 h2o
Monitor
asus vg27aql1a
Miš & tastatura
mchose l7 pro, kbd.fans tofu65 raw alu - cream soda switches - gmk serika 2 keycaps
Pristup internetu
  1. Optički internet
instalirao sam ubuntu, izabrao 4 rezolucije 1280x1024, 1024x768, 800x600 i 640x480
graficka je nv6600 agp
monitor je samsung 913n
kada se pokrece X pojavi mi se sledeca slika (vidi attachment)
a evo i sadrzaja xorg.conf
Kod:
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
# (Type "man /etc/X11/xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
#   sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
	FontPath	"/usr/share/X11/fonts/misc"
	FontPath	"/usr/share/X11/fonts/cyrillic"
	FontPath	"/usr/share/X11/fonts/100dpi/:unscaled"
	FontPath	"/usr/share/X11/fonts/75dpi/:unscaled"
	FontPath	"/usr/share/X11/fonts/Type1"
	FontPath	"/usr/share/X11/fonts/100dpi"
	FontPath	"/usr/share/X11/fonts/75dpi"
	FontPath	"/usr/share/fonts/X11/misc"
	# path to defoma fonts
	FontPath	"/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
	Load	"i2c"
	Load	"bitmap"
	Load	"ddc"
	Load	"dri"
	Load	"extmod"
	Load	"freetype"
	Load	"glx"
	Load	"int10"
	Load	"type1"
	Load	"vbe"
EndSection
Section "InputDevice"
	Identifier	"Generic Keyboard"
	Driver		"kbd"
	Option		"CoreKeyboard"
	Option		"XkbRules"	"xorg"
	Option		"XkbModel"	"pc105"
	Option		"XkbLayout"	"us"
	Option		"XkbOptions"	"lv3:ralt_switch"
EndSection
	Identifier	"Configured Mouse"
	Driver		"mouse"
	Option		"CorePointer"
	Option		"Device"		"/dev/input/mice"
	Option		"Protocol"		"ExplorerPS/2"
	Option		"ZAxisMapping"		"4 5"
	Option		"Emulate3Buttons"	"true"
EndSection
  Driver        "wacom"
  Identifier    "stylus"
  Option        "Device"        "/dev/wacom"          # Change to
                                                      # /dev/input/event
                                                      # for USB
  Option        "Type"          "stylus"
  Option        "ForceDevice"   "ISDV4"               # Tablet PC ONLY
EndSection
  Driver        "wacom"
  Identifier    "eraser"
                                                      # /dev/input/event
                                                      # for USB
  Option        "Type"          "eraser"
EndSection
  Driver        "wacom"
  Identifier    "cursor"
                                                      # /dev/input/event
                                                      # for USB
  Option        "Type"          "cursor"
EndSection
Section "Device"
	Identifier	"NVIDIA Corporation NV43 [GeForce 6600 GT]"
	Driver		"nv"
	BusID		"PCI:1:0:0"
EndSection
Section "Monitor"
	Identifier	"Generic Monitor"
	Option		"DPMS"
	HorizSync	28-64
	VertRefresh	60-72
EndSection
Section "Screen"
	Identifier	"Default Screen"
	Device		"NVIDIA Corporation NV43 [GeForce 6600 GT]"
	Monitor		"Generic Monitor"
	DefaultDepth	16
	SubSection "Display"
		Depth		1
		Modes		"1280x1024" "1024x768" "800x600" "640x480"
	EndSubSection
		Depth		4
	EndSubSection
		Depth		8
	EndSubSection
		Depth		15
	EndSubSection
		Depth		16
	EndSubSection
		Depth		24
	EndSubSection
EndSection
Section "ServerLayout"
	Identifier	"Default Layout"
	Screen		"Default Screen"
	InputDevice	"Generic Keyboard"
	InputDevice	"Configured Mouse"
	InputDevice     "stylus" "SendCoreEvents"
	InputDevice     "cursor" "SendCoreEvents"
	InputDevice     "eraser" "SendCoreEvents"
EndSection
Section "DRI"
	Mode	0666
EndSection
probao sam i sa
Kod:
DefaultDepth	24
i da uklonim
Kod:
"1280x1024"
ali uvek dobijem isto...
sta da mu radim?
    323.4 KB · Pregleda: 129
Probaj da komentiraš linije sa osvežavanjima. Znam da recimo X pod Fedorom može da iščita osvežavanja monitora prilikom pokretanja. To je doduše bilo sa nVidijinim drajverima, ali šta te košta da probaš. Samo ispred "HorizSync" i "VertRefresh" linija stavi "#".
namestio sam da radi, ali nemam 1280x1024 nvidia 1.0.9746 drajveri
Vrati "1280x1024" i default depth "24".
Kao root ukucaj:
#ddcprobe
ili
#xresprobe nv
Trebao bi dobiti detaljne podatke o monitoru (ddcprobe) ili osnovne podatke o max rezoluciji i frekvencijama (xresprobe <driver>).
Zanimaju te Horizontalna i Vertikalna frekvencija koje staviš na odgovarajuća mjesta pod sekcijom Monitor:
HorizSync
VertRefresh
Ja bih pokušao još sa dodavanjem modline-a. Ideš na online modeline generator i upišeš rezoluciju (x i y)i frekvenciju za koju si siguran da monitor može koristiti pri toj rezoluciji:
http://www.sh.nu/nvidia/gtf.php
Izgenerirane linije staviš unutar sekcije "Monitor" u xorg.conf-u
Ako koristiš closed source Nvidia drivere tada pod sekcijom "Device" moraš imati:
Driver "nvidia"
umjesto
Driver "nv"
Također moraš imati zakomentiranu sljedeću liniju pod sekcijom "Module"
Load "dri"
Postoji još opcija za forsiranje modlinea, jer ponekad X-i discardaju tu postavku sa closed source NV driverima. Unutar sekcije "Screen" treba dodati liniju:
Option "UseEdidFreqs" "false"
Dokumentacija:
http://ubuntuforums.org/showthread.php?t=83973
https://help.ubuntu.com/community/FixVideoResolutionHowto
http://wiki.x.org/wiki/FAQVideoModes
