tv zaglavio u "aging view", pomoc????
oogabooga
odjednom, pre 20 minuta mi tv ode u neki "aging view" mode, menja boje na ekranu i nemogu da izadjem iz toga. gasio ga jedino mogu na izvalcenje stekera iz struje, i kad ga gurnem nazad, sam se upali i iopet ode u ovaj mod. tv je Fox 50DLE888, u uputstvu nemogu nista da nadjem.
ima li ko ideju sta da radim?
hvala
Možda...
"I turned the TV off and back on using the TV switch not the remote. This got the TV normal again."
Sent from my SM-G965F using Tapatalk
da, pomoglo je....... jedino prokrvarih dok sam mu nasao taj mali panel sa komandama na kucistu tv.....
a kakva je to uopste gulpost od "aging view" moda?
"What you are describing is the same as the pixel test they use in the factory to make sure the panel is working.
They have a diagnostics screen they use to test the TV before they ship it out. It is closed by pressing the "exit" button on the remote."
