touchpad ne radi posle svakog drugog restarta
operic
ljudi, drugar ima jako cudan problem sa laptopom.
SVAKI drugi put kada pali/restartuje komp desava mu se da touchpad ne reaguje na prst, dok usb mish (koga nakaci naknadno, posle ovog problema) radi normalno.
resetuje komp, sve proradi, resetuje komp opet - touchpad ne radi :wall:
evo sta mu se javlja u event vieweru posle spornog restarta:
Kod:
The driver \Driver\usbohci failed to load for the device PCI\VEN_1002&DEV_4398&SUBSYS_30E3103C&REV_00\3&2b8e0b4b&0&99.
The driver \Driver\usbohci failed to load for the device PCI\VEN_1002&DEV_4397&SUBSYS_30E3103C&REV_00\3&2b8e0b4b&0&98.
The driver \Driver\usbehci failed to load for the device PCI\VEN_1002&DEV_4396&SUBSYS_30E3103C&REV_00\3&2b8e0b4b&0&9A.
The driver \Driver\TPM failed to load for the device ACPI\IFX0102\4&19a5904&0.
The driver \Driver\HDAudBus failed to load for the device PCI\VEN_1002&DEV_4383&SUBSYS_30EE103C&REV_00\3&2b8e0b4b&0&A2.
The driver \Driver\usbehci failed to load for the device PCI\VEN_1002&DEV_4396&SUBSYS_30E3103C&REV_00\3&2b8e0b4b&0&92.
The driver \Driver\b57nd60x failed to load for the device PCI\VEN_14E4&DEV_1693&SUBSYS_30E3103C&REV_02\4&3276522&0&0020.
The driver \Driver\atikmdag failed to load for the device PCI\VEN_1002&DEV_9612&SUBSYS_30E3103C&REV_00\4&1e891fba&0&2808.
The driver \Driver\BCM43XX failed to load for the device PCI\VEN_14E4&DEV_4315&SUBSYS_137D103C&REV_01\4&37f82379&0&0048.
The driver \Driver\usbohci failed to load for the device PCI\VEN_1002&DEV_4398&SUBSYS_30E3103C&REV_00\3&2b8e0b4b&0&91.
The driver \Driver\usbohci failed to load for the device PCI\VEN_1002&DEV_4397&SUBSYS_30E3103C&REV_00\3&2b8e0b4b&0&90.
The driver \Driver\CmBatt failed to load for the device ACPI\PNP0C0A\1.
The driver \Driver\usbohci failed to load for the device PCI\VEN_1002&DEV_4399&SUBSYS_30E3103C&REV_00\3&2b8e0b4b&0&A5.
The driver \Driver\CmBatt failed to load for the device ACPI\PNP0C0A\2.
The driver \Driver\WmiAcpi failed to load for the device ACPI\PNP0C14\0.
The driver \Driver\CmBatt failed to load for the device ACPI\ACPI0003\2&daba3ff&2.
The driver \Driver\Parport failed to load for the device ACPI\PNP0401\5&de4e6ff&0.
The driver \Driver\Serenum failed to load for the device ACPI\PNP0501\5&de4e6ff&0.
The driver \Driver\i8042prt failed to load for the device ACPI\PNP0303\4&19a5904&0.
The driver \Driver\1394ohci failed to load for the device PCI\VEN_11C1&DEV_5811&SUBSYS_30E3103C&REV_70\4&c9a676e&0&30A4.
The driver \Driver\i8042prt failed to load for the device ACPI\SYN0141\4&19a5904&0.
The driver \Driver\kbdclass failed to load for the device Root\RDP_KBD\0000.
The driver \Driver\mouclass failed to load for the device Root\RDP_MOU\0000.
The driver \Driver\RasSstp failed to load for the device Root\MS_SSTPMINIPORT\0000.
The driver \Driver\rdpbus failed to load for the device Root\RDPBUS\0000.
The driver \Driver\swenum failed to load for the device Root\SYSTEM\0000.
The driver \Driver\umbus failed to load for the device Root\UMBUS\0000.
The driver \Driver\Rasl2tp failed to load for the device Root\MS_L2TPMINIPORT\0000.
The driver \Driver\NdisTapi failed to load for the device Root\MS_NDISWANBH\0000.
The driver \Driver\CompositeBus failed to load for the device Root\COMPOSITEBUS\0000.
The driver \Driver\RasAgileVpn failed to load for the device Root\MS_AGILEVPNMINIPORT\0000.
The driver \Driver\RasPppoe failed to load for the device Root\MS_PPPOEMINIPORT\0000.
The driver \Driver\PptpMiniport failed to load for the device Root\MS_PPTPMINIPORT\0000.
The driver \Driver\NdisTapi failed to load for the device Root\MS_NDISWANIP\0000.
The driver \Driver\NdisTapi failed to load for the device Root\MS_NDISWANIPV6\0000.
u pitanju je HP 6735b i Windows 7.
da li vam pada na pamet sta moze da bude u pitanju? :S:
