Toshiba Satelite L40-18W,problem sa WLAN
gnidza
Kupio sam skoro laptop Toshiba Satelite L40-18W i instalirao Vista Home Premium,
potom sa Toshibinog sajta skinuo drajver za Realtek bezicnu karticu i instalirao ga i pise da je sve ok u "device manager-u"
Medjutim nije mi jasno kako funkcionise?
na laptop-u imam prekidac za karticu koji ne reaguje
(ima cak i mala dioda koja nikad nesija)
a postoji varijanta i da pritisnem taster FN+F8 koji isto sluzi za paljenje i opet nista
jel mozda postoji neki firewall koji to blokira ili neko stelovanje u visti u control panel-u koje treba da odradim....?
pomoc!
Meni se slicna stvar desila na laptopu HP nx7400, odjednom nisam mogao da ukljucim wireless ni bluetooth, svasta sam pokusavao i nisam uspeo da vratim sve u normalu. Pomogla je reinstalacija windowsa, e sada to je bilo u XP-u mozda neko zna kako da resis problem u Visti. Probaj cisto provere radi da instaliras XP i vidi da li hoce da ti radi. Jesi li ispostovao redosled instaliranja drajvera i jesi li instalirao sve drajvere koje Toshiba preporucuje?
Installing the Toshiba Drivers – 1: Driver Installation Order
Copy the driver package to C:\ on your freshly installed Satellite L40.
Run C:\L40_Driver_Package\English\Chipset Driver\Setup.exe, follow the
instructions and restart your system.
Run C:\L40_Driver_Package\English\Disply Driver Intel\Setup.exe, follow
the instructions and restart your system.
Run C:\L40_Driver_Package\English\Sound Driver\Setup.exe, follow the
Run C:\L40_Driver_Package\English\Network Driver\Setup.exe, follow
Run C:\L40_Driver_Package\English\TouchPad Driver Synaptics\
Setup.exe, follow the instructions and restart your system.
Run C:\L40_Driver_Package\English\Wireless Network Driver Realtek\
Run C:\L40_Driver_Package\English\RICOH R5C8xx Media Driver\
Run C:\L40_Driver_Package\English\Matrix Storage Manager\Setup.exe,
Run C:\L40_Driver_Package\English\Modem Driver\Setup.exe, follow the
Run C:\L40_Driver_Package\English\ATK Hotkey Driver\2ksetup.exe,
Run C:\L40_Driver_Package\English\ATK Hotkey Utility Driver\
Run C:\L40_Driver_Package\English\Toshiba Accessibility Driver\
Run C:\L40_Driver_Package\English\Assist\Setup.exe, follow the
Note: The above installation order is for the Non-OS version of the Satellite L40. If your
computer comes with an Atheros Wireless LAN adapter, do NOT install the RealTek
WLAN driver. Instead run the Wireless Network Driver Atheros setup after the
Modem installation and the Atheros Client Utility setup after installing the ATK
Hotkey drivers
jel ima reshenja za ovaj problem da ne bi otvarao novi post, imam isti problem, do juce mi je radio wireless i probao sam nesto fn f8 i posle toga nikako da ukljucim non stop pokazuje no wireless networks found, a imam ap u sobi morao bi da hvata 100 mi je signal tu. Os je xp ali gde da preinstaliram nije valjda da nema resenja ili mora xp da se "opali"? Laptop mi je toshiba satelite L40 neznam sta da radim..... pomagajte!!!
