digital01
Sa stranog foruma ako da se registrujete na TL, nisam mogao da prevodim, predpostavaljam da razumete. Kazu da radi, mada moze da se desi da vas odbije, pa da probate ponovo za nekih pola sata.
Ok I can confirm that this is indeed completely real and I just got an account there, but it might not be open for long. Just use this link irc://irc.torrentleech.org:7011/invites to get into the channel if you already have an irc client installed.Now inside the invites channel type "!invite [youremail]". It should kick you out of the channel and say that you're invited. That's it. It sends you an invite and you're done.
