Meni je isto na E6750 prikazivano mahom 95C tako da kontam da je najverovatnije to ali ne brini se tu temperaturu ni leti ne mozhesh da dobijesh u normalnom radu, igrama itd. Chak ni pri stresovanju leti pod TRUE ne mozhe da pridje tome. :wave:
Intel has said the absolute temps vary a few C at tjmax. Intel typically does not supply averages, they typically use max it could be. Which means the assumption is that temps may vary from 100max at tjmax to few C below (but that assumption fits with IR readings and papers documenting 3C max gradient on pentium across IHS, possibly ?1C less on 45/65nm). I am using an "assumed to be average absolute temp" for my E8400, tjmax 97 (since I IR'ed mine at 95) despite 100 tjmax, but almost assuredly tjmax is 100 for all cpus with tcase max spec of ~70-74.
