Thunderbird gmail problem
scorpionx
Poštovan
Instalirao sam thunderbird 31.1, yahoo i outlook rade bez problema ali kad probam da napravim nalog za gmail uporno mi izbacuje poruku da username ili password nisu tacni. Prvi put koristim thunderbird molim za pomoc.
jesi uradio ovo
Get started with IMAP and POP3
Select an option below for instructions on how to enable POP or IMAPI want to enable POP
You can read your Gmail messages from a client or device that supports POP, like Microsoft Outlook.
Here's how to enable POP in Gmail:
Sign in to Gmail.
Click the gear in the top right.
Select Settings.
Click Forwarding and POP/IMAP.
Select Enable POP for all mail or Enable POP for mail that arrives from now on.
Choose what to do with your messages after your POP client or device receives them.
Click Save Changes.
Although the radio button next to your selected option may not stay selected, Gmail displays the status next to 'POP Status:.' When you enable POP, your settings display 'POP Status: POP is enabled.'
If your POP settings are turned off, the status will indicate that POP is disabled.
Once you've enabled POP in your Gmail settings, you need to configure your client. Select a client below to see specific configuration instructions.Thunderbird
Open Thunderbird, enter your account information and click Continue.
Full Name: [your name]
Email Address: your full email address [[email protected], or username@your_domain.com for Google Apps users]
Password: your Gmail password
Select POP3.
Thunderbird will do all of the setup for you, but confirm your settings with the information below.
If you're setting up POP for the first time, confirm your settings to make sure they're correctOk, confirm my settings
If you're not using one of the clients or devices above, we offer general instructions on configuring some clients below. If you encounter difficulties, we suggest contacting your mail client's customer support department -- we're unable to provide assistance for clients not listed above.
Standard configuration instructions:
Incoming Mail (POP3) Server - requires SSL: pop.gmail.com
Use SSL: Yes
Port: 995
Outgoing Mail (SMTP) Server - requires TLS or SSL: smtp.gmail.com
Use Authentication: Yes
Port for TLS/STARTTLS: 587
Port for SSL: 465
Server timeouts Greater than 1 minute, we recommend 5
Full Name or Display Name: [your name]
Account Name or User Name: your full email address (including @gmail.com or @your_domain.com)
Email Address: your email address ([email protected] or username@your_domain.com)
Unless you're using recent mode to download mail to multiple clients, make sure you've opted not to leave messages on the server. Your POP settings in Gmail settings are what determines whether or not messages stay on the server, so this setting in your client won't affect how Gmail handles your mail.
If your client does not support SMTP authentication, you won't be able to send mail through your client using your Gmail address.
If you're having trouble sending mail but you've confirmed that encryption is active for SMTP in your mail client, try to configure your SMTP server on a different port (465 or 587).
