The Sun Will Explode In Less Than Six Years!
EagleOne
Mislili ste da su ona flash zezanja kratila zivce, pa vi nista niste videli :-/ ...
Yahoo news...
EagleOne je napisao(la):
Yahoo news...
Moracemo da pitamo fikija sta misli o ovome.:D :D :D
Ashley je napisao(la):
Po ugledu na Weekly World News je napravljena ovdasnja Zona Sumraka, tako da se ne sekiras puno :)
Kad bi se stvarno bilo tacno da ce se desiti, mislish da bi nam rekli ... :) A, opet zamisli situaciju da je istina boom, sta bi radili ...
p.s. "Ovaj, onaj ako tada bude noc kod nas nista nam nece biti samo ce amer'kanci da izgore, jel' tako ti sto sjedish pored tog malog nosatog" :D
p.s.s. Za one koji su @lite,@home :
Wednesday September 18, 2002
By GEORGE SANFORD
The Sun is overheating and will soon blow up . . . taking Earth and the rest of the solar system with it, scientists warn.
The alert was issued after an international satellite photographed a massive explosion on the surface of the Sun that sent a plume of fire 30 times longer than the diameter of Earth blasting into space.
"It's a sign that the Sun is ready to blow . . . I don't know if I can put it any more plainly than that," says Dutch astrophysicist Dr. Piers Van der Meer, a top expert affiliated with the European Space Agency.
"It will be like a nuclear bomb trillions of times more powerful than the one dropped on Hiroshima going off at the center of our solar system.
"When that happens Earth will be instantly incinerated along with all life on it. It's like when a marshmallow falls into a fire, blackens and melts."
Scientists say the problem is the Sun is literally getting too hot.
The core temperature of the Sun is normally 27 million degrees Fahrenheit. But in recent years it's climbed to an alarming 49 million degrees, says Dr. Van der Meer, leader of a team of Amsterdam-based space scientists who've been tracking the changes in the Sun.
"It's quite similar to when a star goes supernova at the end of its life," Dr. Van der Meer explains. "Over the past 11 years, we've seen our Sun go through changes frighteningly like those that took place in Kepler's Star right before it was observed going supernova in 1604."
Temperatures on the surface of the Sun have been steadily climbing over the past decade, the scientists say.
"This, we believe, not man-made pollution, is responsible for global warming and the alarming effects that we've seen take place on Earth such as the melt-down of the Antarctic ice shelves," asserted Dr. Van der Meer.
The July 1 images were taken by the space-based Solar and Heliospheric Observatory (SOHO), a satellite designed to study the internal structure of the Sun and operated jointly by NASA and the European Space Agency.
"The explosion . . . known technically as an eruptive prominence . . . was colossal," said Dr. Van der Meer. "This is the final warning sign we've all been dreading."
The Dutch scientists calculate that if temperatures keep climbing at the current rate the Sun will be unable to sustain itself.
"It will blow apart like an out-of-control nuclear reactor within six years," predicts Dr. Van der Meer.
NASA refuses to confirm the Euro-pean scientists' assertions and a White House source said, "We don't need anyone spreading more panic now."
Pa kad si vec sve quote-ovao trebao si da navedes i da je vest objavljenja pod "Entertainment News & Gossip", jer je to bitna informacija da bi se shvatila prava "dimenzija" vesti ! :D
Ovaj "slucjno ubaceni" deo koji po meni nema mnogo veze sa temom generalno, deluje vise kao deterdzent (citaj - sredstvo za "pranje ruku"). Zna se ko je najveci zagadjivac planete
tacno je da će sunce potrositi svoje gorivo,odnosno se ugasiti.
tačno je i da će to biti za 6,ali 6000000000god./šest milijardi godina/:)
ma dosta je da sunce 'radi' josh 70ak godina :D:D
drapin je napisao(la):
Veruj mi nisam obratio paznju na taj "detalj" samo sam forward-ovao vest ...
p.s. a kao bilo bi lose jedno 5-6 dana da zivimo u ubedjenju kraja, naravno laznom ubedjenju :)
sharp_blade je napisao(la):
Tacnije za 7.5 milijardi godina.
Mogu jos da kazem da su promasili temperauru suncevog jezgra. Ona iznosi oko 15 miliona K a ne 27.
A ta temperatura ne moze da se menja tek tako, jer ona zavisi od pritiska gravitacije Sunceve mase. Kao sto znamo niko Suncu nije dodao nekoliko biliona tona tako da se ta temperatura naravno nije promenila.
A eksplozije na Suncu (protuberance) nisu nomalo retka pojava.
