source:
http://www.gameboomers.com/wtcheats/pcSs/secretsofdavinci.htm
Leonardo's bedroom:
Secret compartment - Go to the sign of fire (upright triangle) bedpost at bottom right of bed) and click on the fire sign. Valdo will quote - "at the foot of the sacred fire of the house of dreams". Look down under the carpet and see a board. Use the knife on the board. Take a new sheet of paper and key mould. Add the new sheet of paper to the portfolio. Read the illegible text at the bottom of the key mould drawing using the mirror. Read the next page also. Bronze is an alloy of copper and tin. Gold is malleable metal.
Forge-mill:
Go forward to the forge. Pick up dry leaves and axe outside the forge. Enter and look around and see the furnace, anvil on the lower level and the mill on the right side. Pick up the beekeeper's veil hanging from the shelf.
Furnace - Place dry leaves and split logs in the furnace. Use the lighter on the logs.
Key - Place the key mold on the table on the right of furnace. Place pewter dish and copper object (alternative is bronze that can be bought from Saturnin) in the crucible. Click on handle of the post on the left to raise the crucible. Swing the arm to move it inside the furnace. Click on handle again to lower the crucible with bronze. Remove the arm out of the furnace. Lift the furnace cover and place it on furnace.
Turn right and take the gloves from side of the table. In inventory, click the gloves on Valdo.
Take the furnace cover off after wearing the gloves and lay it on the floor. Swing the arm to the furnace, click the handle, swing the arm out and click the handle again to lower the crucible.
With gloves on, pour the molten bronze on the key mould. Open the mould and take bronze key. Take the key mould again. Click the gloves off Valdo.
Mill - Look outside and see that the water wheel is stopped. In inventory, click the reed on Valdo. LOL!
Dive in the water. Look at the water wheel clogged by sticks. Use the knife to cut the sticks. The water wheel turns.
Flour - Go back inside the mill. Place grains of wheat on the bin at top level. Pull the lever beside the bucket by the door to get flour.
