Tastatura USB MT Quark RF wir
drdekzar
Veoma zanimljiva tastatura, danas sam je video u jednoj radnji kod nas
http://www.media-tech.eu/products/keyboard-and-mouse-sets/MT1419-US
Technical specification
2.4G wireless micro multimedia keyboard
Built in touchpad
60 keys and 8 media buttons
Effective operation range: up to 10m
USB interface
Nano size USB receiver
Powered by 2xAAA alkaline batteries (not included)
Windows XP/VISTA/Win 7 32/64-bit compatible
Weight: 116g
Product description
Media-Tech presents the essential addition for fans of multimedia: a "small-big" QUARK RF1419 keyboard that serves mainly the function of PC HTPC controller (Home Theater Personal Computer), working with Playstation 3 and XBOX360 consoles, tablets, and devices based on Android equipped with a USB port.
The touchpad built in this device allows scrolling documents and pages horizontally and vertically, a smooth transition between previous / next page, also offers a zoom function.
Keyboard, similar to the size of the remote control, besides a standard keys, is also equipped with 8 additional multimedia function keys.
QUARK RF MT1419 is powered by two AAA batteries, measures 155x82x23mm and weighs just 116g! The set includes also tested, applied to most of wireless devices of Media-Tech, nano-receiver hidden in the casing, with a range of up to 10m.
The keyboard has been equipped with ON/OFF button, helping to reduce battery consumption..
Why to invest in QUARK RF MT1419 keyboard?
- You get a fully mobile, extremely functional device 2 in 1,
- You get very comfortable to use, great looking gadget,
- You have complete control over the multimedia in chosen device - you can sit comfortably on the couch and remotely operate your PC.
    142.6 KB · Pregleda: 98
    201.2 KB · Pregleda: 132
Ajde napisi gde i po kojoj ceni, deluje OK za HTPC..
Danas sam ga testirao i mogu reci da sam pozitivno iznenadjen.Sve veoma lepo funkcionise,tasteri su veoma dobro uradjeni i nije mi se desavalo da pritiskam po dva iako imam deblje prste :), Touch radi odlicno i desni/levi klik su osmisljeni extra ( na vrhu tastatura sa desne/leve strane se pritiska nesto slicno Dzojsticima :) ).Probao sam na racunaru i sasvim sam lepo kucao u exelu, probao internet......
Mislim da je ovo pravi pogodak za Tablete koji imaju USB danas sam ga probao na Toshibi A100 i to radi savrseno
