Nisam pisao tekstove na srpskom pa cu ovako postovati:
Nasli smo i prevodioca pa ce uskoro biti i verzija programa na srpskom jeziku (posto je autor uvek imao bolju ocenu iz engleskog nego iz srpskog u skoli pa se nije hteo upustiti u poduhvat prevodjenja)
Inace program se ranije zvao TaskGuardian ali za novu verziju dobio je i novo ime. Personal verzija je besplatna i nadam se da ce vam koristiti.
Vase ideje, sugestije i konstruktivne kritike mozete da ostavljate u ovoj temi.
PS. Ako moderator smatra da bi trebalo dodati post o ovom programu u Sticky teme ovog podforuma nemam nista protiv ali bih zeleo da ova tema ostane ovde kako bih mogao da cujem misljenja. Sticky teme:
Press Release
Ever wondered what hidden features applications installed on your computer have? Scratching your head with no clue of what are those tasks with cryptic name and no user interface running on your system? TaskPatrol gives you answers to these and many other questions!
With the set of advanced security techniques, TaskPatrol is able to identify and remove malicious software from your computer. These include, but are not limited to, malware, spyware, adware, trojans, backdoors, suspicious browser helper objects... Unlike other similar software, TaskPatrol implements a security engine capable of analyzing applications and finding potentially dangerous features and contents within them. Each suspicious property found will be presented to the user in a non-technical easy to understand way, with suggestions on how to handle it. These unique features enable TaskPatrol to spot even currently unknown malware, which are not present in any database today.
With TaskPatrol no application is a running "black box" anymore. Take a peek under the hood, review application's features and get detailed plain-English explanation about them. Ignorance is not bliss, learn everything you can about running programs and take control of them before they take control of your computer!
More Info: http://www.asmdev.net/products/taskpatrol/index.html
Download: http://www.asmdev.net/products/taskpatrol/taskpatrol.zip
Virusi/trojanci/spyware/adware/sumnjivi procesi Info...
http://www.benchmark.co.yu/forum/showthread.php?t=82860
freeware lista programa
http://www.benchmark.co.yu/forum/showthread.php?t=89947
