SweetFX Shader Suite
amdpower
...on thin ice...
Here you can download SweetFX Shader Suite Version 1.3 - SweetFX is a universal image improvement and tweaking mod, that works with almost any 32bit DirectX 9, 10 or 11 game or application. This software is made by Guru3D's own CeeJay.dk and as will be supported here on Guru3D.com to the fullest extend.
The goal of this software is to provide similar tools to games in realtime, as video processing software provides for movies and videos. You will need some technical grasp to be able to work with this software though. As such we recommend you to read the information below carefully.
Effects included:
SMAA Anti-aliasing : Anti-aliases the image using the SMAA technique - see http://www.iryoku.com/smaa/
LumaSharpen : Sharpens the image, making details easier to see
Bloom : Makes strong lights bleed their light into their surroundings
HDR : Mimics an HDR tonemapped look
Technicolor : Makes the image look like it was processed using a three-strip Technicolor process - see http://en.wikipedia.org/wiki/Technicolor
Cineon DPX : Makes the image look like it was converted from film to Cineon DPX. Can be used to create a "sunny" look.
Lift Gamma Gain : Adjust brightness and color of shadows, midtones and highlights (avoids clipping)
Tonemap : Adjust gamma, exposure, saturation, bleach and defog. (may cause clipping)
Vibrance : Intelligently saturates (or desaturates if you use negative values) the pixels depending on their original saturation.
Curves : Contrast adjustments using S-curves.
Sepia : Sepia tones the image - see http://en.wikipedia.org/wiki/Sepia_tone#Sepia_toning
Vignette : Darkens the edges of the image to make it look more like it was shot with a camera lens. - see http://en.wikipedia.org/wiki/Vignetting
Dither : Applies dithering to simulate more colors than your monitor can display. This lessens banding artifacts - see http://en.wikipedia.org/wiki/Dithering#Digital_photography_and_image_processing
Splitscreen : Enables the before-and-after splitscreen comparison mode.
You can find new releases and information of SweetFX in our dedicated thread on the Guru3D forums :
http://forums.guru3d.com/showthread.php?t=368880
http://www.guru3d.com/files_details/sweetfx_shader_suite_download.html
Jel ovo neko probao i ako moze malo bolje objasnjenje za nas koji naglabamo engleski.🙂
PS Koji je ovo softver na slikama za prikaz stanja graficke?
Sve preporuke
Čudi me da se o ovome ne diskutuje na forumu, a forum pun gejmera i ljubitelja zelenih i crvenih.
:laugh:
Ovoj temi je mesto u podforumu "Grafičke karte".
Evo ja koristim, polako za sve više igara.
Kod nekih se vidi drastična razlika, kod nekih manje, sve zavisi. Najvažnije je da ne utiče na performanse.
Train Simulator 2013 izgleda 100x bolje sa SweetFX nego bez njega!
http://steamcommunity.com/app/24010/discussions/0/846938350926305494/
Postaviću skrinove kasnije. Problem je što Steam screenshot manager "ne uslika" igru sa uključenim SweetFX-om 🙁.
Skinite GUI konfigurator ovde:
http://sweetfx.thelazy.net/
...da se ne zezate sa tekstualnim fajlovima i kopiranjem fajlova u .exe folder igre.
