Sve za audio,DivX,DVD obradu
POSSESSED
Ko voli, nek izvoli...
http://www.doom9.org/software2.htm
Audio Tools
AACEnc 2.15 - probably the highest quality AAC encoder
AacMachine 0.3 - GUI for AACEnc
AacMachine 0.45 - GUI for AACEnc, doesn't support mp3 input, framerate changes
and silence appending (as 0.3 does) but has no problem with long files
AC3Machine 0.3 - AC3 transcoding program
AC3 delay corrector - adjusts the delay of AC3 movies, useful for miniDVD and
DVD authoring
Azid 1.8 - command line based ac3 decoding - correct Dolby Surround downmix,
DRC, etc.
BeSplit 0.8 - simple AAC/AC3/WAV/MPx cutter
BeSure 1.2 - direct VOB/AC3 to CD audio (regular, Dolby Digital or DTS CD)
conversion
BeSweet 1.3 - Advanced tool for transcoding popular audio formats
(AC3/MP3/OGG/MP2/AIFF/MPA/WAV/LPCM) Features includes : Normalize,
Dynamic-Range-Compression, Sample-Rate-Conversion, Frame-Rate-Conversion, Delay
Assertion & Silence Insertion.
BeSweet downmix plugin - 5.1ch -> 2ch downmix with better channel separation
BeSweet GUI 0.6b50 - GUI for BeSweet, azid, lame, WavBooster, ssrc and toolame
DeDynamic 0.2 - real time dynamic range compression Direct Show filter
Graphedit - use your DVD player's direct show filter to extract the audio
HeadAC3he 0.23a - smart & fast AC3 -> WAV/MP3/OGG/AC3-WAV transcoding utility
(contains SSE dlls. MMX/SSE2 dlls can be downloaded here)
Lame 3.92 - best and free MP3 encoder
Morgan stream switcher - allows 2 audio tracks in WMP
MP3Trim 1.7 - allows you to cut MP3s directly.
Mp3wav 1.0 - cli tool to add a WAV RIFF header to MP3 files
OggMachine - AC3/WAV/MP2/MP3 -> Ogg converter based on BeSweet
Radium MP3 codec 1.2 - mp3 codec
SSRC 1.29 - probably the best sampling rate converter
Synchronizer 0.8 - helps you synching your DivX movies
Synch.zip - little program used to calculate synch values when using secondary
synching method
TFM Audio filter - real time playback dynamic range compression
Toolame 0.2i - command line based WAV -> mp2 encoding, can be used as external
encoder for TMPG
Toolame GUI - a GUI for toolame
WaveBooster 0.51 - normalize and dynamic reduction for all kinds of WAV files -
experimental version
WAV normalize 0.24.1 - normalize your WAV files
WAV normalize GUI - GUI for the above
Wave Lenght Adjust 0.26 - adjusts the lenght of wav files
Wavemp3 1.2 - adds WAV RIFF headers to MP3 files.
WaveOut fix - allows you to use the SPDIF output easily with AVI/AC3 without
using Graphedit
Wbias 0.8 - GUI for BeSplit
WMA2WAV - creates WAVs out of WMA files
Vob2audio - replacement for Graphedit, allows for VOB -> WAV/MP3 conversion
using DS filters
AVI Editing tools
AviDefreezer - fixes frozen frames
Avifrate1.10 - framerate changer for Avis
AviMux 0.4 - simple program to multiplex multiple audio tracks and a video track
to one AVI
AviUtl 0.98b - includes English patch and English m4c plugin.
AviUtl filter plugins - a couple of untranslated filters
AviUtl jump filter English
Alphatv Avi Editor - adds copyright info to your AVI files
DivX Fix 1.07 - to fix broken DivX downloads and crashed ripping sessions. NOT
for frozen frames!
DivX4log - DivX4 logfile editing utility
FourCC changer - allows you to change the fourCC code of your movies
Ogg Cutter - utility to cut Ogg Media streams
OggMux - ogg media stream multiplexing utility
VirtualDub 1.4.10 - latest release
VirtualDub 1.4c-asf - can open ASF files
Calculators
ABRCalc - a bitrate calculator for ABR mp3 files
Bearson's Bitrate Calculator - Bitrate calculator, what else?
DiffCalc - util for Fair Use's Diff Calc method
DVD-R calculator - to help you calculate the bitrate when using IfoEdit
DivX4 bitrate calculator - tailored for DivX4
Framecalc - enter the lenght of the movie and your framerate and you'll get the
number of frames
Codecs
DivX 3.11 alpha - it appears to me that some people don't know what CTRL-F is...
so learn!!!
DivX 3.11 VKI - a patch to make DivX VKI by default (sometimes DivX 3.11 plus
VKI is referred to as DivX 3.2)
DivX 4.12 - the brand new DivX codec from the projectmayo guys. No relation to
DivX3.x whatsoever, but downward-compatible.
DivX 502 basic - lastest DivX codec by DivXNetworks. The successor of DivX4.
DivX 502 Pro - free version with extra features but contains an additional app
that displays ads every now and then.
DivX antifreeze 0.4 - allows you to play beyond freeze-frames (for DivX3 only)
Huffyuv 0.2.2 - fixes a few issues when being used in CCE
Descrambling / Ripping tools
CSS MISM for Flask 0.60 - allows you to open VOBs/IFOs off the DVD directly
DVD Decrypter 3.0 - includes UDF parsing
DVD Decrypter 2.4 - old version to be used then v3.0 doesn't work
OpenDVD plugin for DVD2AVI (requires at least v1.76) - do not use for anything
but preview!
SmartRipper 2.41 - another DVD Ripper, offers many neat options that no other
ripper has
Vobrator 0.2 - even another rip program, also offers some special features like
pcm dts conversion or pcm extraction.
vStrip 0.8f_css - probably the most versatile ripper
Decoders
DVD2AVI 1.74 THE frameserving tool par excellence
DVD2AVI 1.76 - latest beta version
DVD2AVI 1.82 - includes resizing now
DVD2AVI 1.86 - v1.76 plus lame based mp3 output
DVDx 2.0 - all in one DVD -> VCD/SVCD encoder
FlaskMpeg 0.60 preview
Thunder MISM for Flask 0.60 - allows you to open IFOs and concatenate VOBs (load
the first one.. the rest gets loaded automatically)
Miha iDCT plugins for Flask 0.6x+ - fastest iDCT you can get
AMD optimized iDCT plugins for Flask 0.6x+
FlaskMpeg 0.60 preview 1.1 - copy the files to the directory containing preview
1
FlaskMpeg 0.60 subtitlefix - use this version instead of the other 0.6x
Xmpeg 4.5 - latest FlaskMpeg derivate, much faster than the original
DivX / MPEG-4 Encoders
Fair Use 0.30 - all-in-one (except audio) DVD -> DivX VKI/MM4 encoder
FUBatch 0.9 - batch encoding for Fair Use
Gordian Knot 0.23 - executable only (see above what additional software is
required).
Gordian Knot 0.26 update - update from 0.21 to 0.26
I-Media Mpeg-2 Direct Show filters - allows you to encode AVIs using Graphedit
m4c plugin 03/18 - English version
Madrona 1.3.0 - automates audio processing for Fair Use
Morphix 0.71a - stats file editor for DivX4
Mov2Avi - converts Quicktime files to AVI
mpeg2avi PX3 0.015a - fastest VOB -> AVI encoder
mpeg2avi 0.016 - PX3's work continued
mpeg2avi/ac3dec/vStrip GUI 0.20j - GUI for the mentioned programs
MPEG4IP utilities - mp4 creator and mpeg-4 video and audio creation utilities
(binaries have been created and are distributed independently of the MPEG4IP
project)
Nandub 1.0 RC2 - SBC encoding utility
Nandub 1.0 RC2 lumafix - luma calculations work properly in fast recompress mode
VdubConf 0.2 - allows you to change the codec defaults in GKnot.
Vidomi 469 - all in one DivX encoding utility
Windows Media Encoder Utility GUI - probably the best one
Filters
Audiofilters - contains filters for AVI/AC3 and dual audio AVIs
P.S. Ovo nije ceo spisak ....(10000 karaktera po postu)
