Sta mislite o Panasonic SDR-S7 SD/SDHC kamkorderima?
grozda
Izgledaju prelepo ali vrede li uopst. Kvalitet snimaka ...
Kod:
Weighing just 180 grams and measuring only 41x59x102mm, the Panasonic SDR-S7 is a camcorder you can take just about anywhere, as you would a small digital still camera - the S7 fits nicely in the palm of the hand. This outstanding mobility makes the Panasonic SDR-S7 an ideal choice for business use. Just slip it in a suit pocket or handbag and carry it anywhere. The power turns on or off as soon as the LCD is opened or closed, and Quick Start recording begins in only 0.6 second. This combines with the camera's handy compact size to help catch those sudden shooting opportunities. The S7 comes with 4GB included SDHC card memory. This will allow up to 3 hours & 20 mins of recording (in LP mode). Plus the 16GB SDHC card (RP-SDV16G) allows up to 13 hours & 20 mins (in LP mode). Combine with the VW-BN1E DVD Burner for easy one-touch DVD creation and archiving of your footage without having to use a computer. RRP $549.
What's in the box?
Panasonic SDR-S7
4GB SDHC Card
AC Adaptor
AC Cable
Battery Pack
Hand Strap
AV Cable
USB Cable
CD-Rom
Instruction Booklet
Software - Motion SD Studio Ver. 1.3E
