de.zivkovic
Cenjen
HARD SE ZADNJIH MESEC DANA PONASA CUDNO TJ. BROJI KLUSTERE PRE DIZANJA SISTEMA
A IMAM BUTOVANJE WINDOVS XP SP3 I WINDOVS ULTIMATE 64X
PA SAM SKINUO PAR PROGRAMA
OVO KAZU ONI A STA KAZETE VI
HD TUNE PRO 4.61
HD Tune Pro: SAMSUNG HD642JJ Health
ID Current Worst ThresholdData Status
(01) Raw Read Error Rate 100 99 51 24 ok
(03) Spin Up Time 86 86 11 5190 ok
(04) Start/Stop Count 99 99 0 1206 ok
(05) Reallocated Sector Count 100 100 10 0 ok
(07) Seek Error Rate 100 100 51 0 ok
(08) Seek Time Performance 100 100 15 0 ok
(09) Power On Hours Count 97 97 0 13467 ok
(0A) Spin Retry Count 100 100 51 0 ok
(0B) Calibration Retry Count 100 100 0 1 warning
(0C) Power Cycle Count 99 99 0 1156 ok
(0D) Soft Read Error Rate 100 99 0 24 ok
(B7) (unknown attribute) 100 100 0 0 ok
(B8) End To End Error Detection 100 100 0 0 ok
(BB) Reported Uncorrectable Errors 100 100 0 24 ok
(BC) Command Timeout 100 100 0 0 ok
(BE) Airflow Temperature 59 54 0 689111081 ok
(C2) Temperature 59 52 0 756219945 ok
(C3) Hardware ECC Recovered 100 100 0 18703793 ok
(C4) Reallocated Event Count 100 100 0 0 ok
(C5) Current Pending Sector 100 100 0 1 warning
(C6) Offline Uncorrectable 100 100 0 0 ok
(C7) Ultra DMA CRC Error Count 100 100 0 32 warning
(C8) Write Error Rate 100 100 0 0 ok
(C9) Soft Read Error Rate 99 99 0 24 ok
Health Status : warning
-- General Information --
Application Information
Installed Version . . . . . . . . . . . . . . . : Hard Disk Sentinel 3.50 PRO
Registered to:
Current Date And Time . . . . . . . . . . . . . : 8/31/2011 10:27:55 PM
Health Calculation Method . . . . . . . . . . . : Analyse data field (default)
Computer Information
Computer Name . . . . . . . . . . . . . . . . . : WINCTRL-UAOCYSW
User Name . . . . . . . . . . . . . . . . . . . : DEJA
Computer Type . . . . . . . . . . . . . . . . . : Server
IP Address . . . . . . . . . . . . . . . . . . . : 192.168.1.3
MAC Address . . . . . . . . . . . . . . . . . . : 00-19-DB-CC-70-55
System Uptime . . . . . . . . . . . . . . . . . : 0 days, 3 hours, 36 minutes, 50 seconds
System Up Since . . . . . . . . . . . . . . . . : 8/31/2011 6:51:05 PM
CPU Usage . . . . . . . . . . . . . . . . . . . : CPU #1: 31 %, CPU #2: 40 %
Virtual Memory . . . . . . . . . . . . . . . . . : 8188 MB, Used: 1636 MB (20 %)
System Information
Windows Version . . . . . . . . . . . . . . . . : Windows 7 Ultimate Server (Terminal Server Edition)
CPU Type & Speed #1 . . . . . . . . . . . . . . : AMD Athlon(tm) 64 X2 Dual Core Processor 5200+, 2686 MHz
CPU Type & Speed #2 . . . . . . . . . . . . . . : AMD Athlon(tm) 64 X2 Dual Core Processor 5200+, 2686 MHz
BIOS Manufacturer . . . . . . . . . . . . . . . : ACRSYS - 20090317
Physical Memory Size . . . . . . . . . . . . . . : 4095 MB, Used: 1833 MB (45 %)
Display Adapter . . . . . . . . . . . . . . . . : NVIDIA GeForce 9600 GT
Display Resolution . . . . . . . . . . . . . . . : 1920 x 1080 (32 bit)
Printer #1 . . . . . . . . . . . . . . . . . . . : Fax
Printer #2 . . . . . . . . . . . . . . . . . . . : Microsoft XPS Document Writer
Network Controller #1 . . . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Network Controller #2 . . . . . . . . . . . . . : Bluetooth Device (RFCOMM Protocol TDI)
Network Controller #3 . . . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Optical Drive #1 . . . . . . . . . . . . . . . . : F: TSSTcorp CDDVDW SH-S222L / SB01 (DVD-RAM, DVD-RW, CD-RW)
Optical Drive #2 . . . . . . . . . . . . . . . . : G: PIONEER DVD-RW DVR-212 / 1.21 (DVD-RAM, DVD-RW, CD-RW)
Optical Drive #3 . . . . . . . . . . . . . . . . : H: ELBY CLONEDRIVE / 1.4 (BD, HD DVD, DVD, CD)
PCI Bus
-- Physical Disk Information - Disk: #0: SAMSUNG HD642JJ --
Hard Disk Summary
Hard Disk Number . . . . . . . . . . . . . . . . : 0
Interface . . . . . . . . . . . . . . . . . . . : S-ATA II
Disk Controller . . . . . . . . . . . . . . . . : Standard Dual Channel PCI IDE Controller (ATA)
Disk Location . . . . . . . . . . . . . . . . . : Channel 0, Target 0, Lun 0, Device: 0
Hard Disk Model ID . . . . . . . . . . . . . . . : SAMSUNG HD642JJ
Firmware Revision . . . . . . . . . . . . . . . : 1AA01118
Hard Disk Serial Number . . . . . . . . . . . . : S1AFJ1KS500096
Total Size . . . . . . . . . . . . . . . . . . . : 610477 MB
Power State . . . . . . . . . . . . . . . . . . : Active
Logical Drive(s) . . . . . . . . . . . . . . . . : C: [] D: [] E: []
Current Temperature . . . . . . . . . . . . . . : 41 °C
Maximum Temperature (Ever Measured) . . . . . . : 42 °C, 8/30/2011 8:48:05 PM
Minimum Temperature (Ever Measured) . . . . . . : 39 °C, 8/30/2011 5:45:57 PM
Maximum Temperature (During Entire Lifespan) . . : 46 °C
Power On Time . . . . . . . . . . . . . . . . . : 561 days, 3 hours
Estimated Remaining Lifetime . . . . . . . . . . : more than 1000 days
Health . . . . . . . . . . . . . . . . . . . . . : ###################- 99 % (Excellent)
Performance . . . . . . . . . . . . . . . . . . : #################### 100 % (Excellent)
There are 1 weak sectors found on the disk surface. They may be remapped any time in the later use of the disk.
At this point, warranty replacement of the disk is not yet possible, only if the health drops further.
It is recommended to examine the log of the disk regularly. All new problems found will be logged there.
No actions needed.
ATA Information
Hard Disk Cylinders . . . . . . . . . . . . . . : 1240341
Hard Disk Heads . . . . . . . . . . . . . . . . : 16
Hard Disk Sectors . . . . . . . . . . . . . . . : 63
ATA Revision . . . . . . . . . . . . . . . . . . : ATA/ATAPI-7, ATA8-ACS version 3b
Total Sectors . . . . . . . . . . . . . . . . . : 1250263728
Bytes Per Sector . . . . . . . . . . . . . . . . : 554
Buffer Size . . . . . . . . . . . . . . . . . . : 16384 KB
Multiple Sectors . . . . . . . . . . . . . . . . : 16
Error Correction Bytes . . . . . . . . . . . . . : 4
Unformatted Capacity . . . . . . . . . . . . . . : 660559 MB
Maximum PIO Mode . . . . . . . . . . . . . . . . : 4
Maximum Multiword DMA Mode . . . . . . . . . . . : 2
Maximum UDMA Mode . . . . . . . . . . . . . . . : 300 MB/s (7)
Active UDMA Mode . . . . . . . . . . . . . . . . : 300 MB/s (6)
Minimum Multiword DMA Transfer Time . . . . . . : 120 ns
Recommended Multiword DMA Transfer Time . . . . : 120 ns
Minimum PIO Transfer Time Without IORDY . . . . : 120 ns
Minimum PIO Transfer Time With IORDY . . . . . . : 120 ns
ATA Control Byte . . . . . . . . . . . . . . . . : Valid
ATA Checksum Value . . . . . . . . . . . . . . . : Valid
Acoustic Management Configuration
Acoustic Management . . . . . . . . . . . . . . : Supported
Acoustic Management . . . . . . . . . . . . . . : Disabled
Current Acoustic Level . . . . . . . . . . . . . : Default (00h)
Recommended Acoustic Level . . . . . . . . . . . : Max performance and volume (FEh)
S.M.A.R.T. Details
Off-line Data Collection Status . . . . . . . . : Never Started
Self Test Execution Status . . . . . . . . . . . : Successfully Completed
Total Time To Complete Off-line Data Collection : 7591 seconds
Execute Off-line Immediate . . . . . . . . . . . : Supported
Abort/restart Off-line By Host . . . . . . . . . : Not supported
Off-line Read Scanning . . . . . . . . . . . . . : Supported
Short Self-test . . . . . . . . . . . . . . . . : Supported
Extended Self-test . . . . . . . . . . . . . . . : Supported
Conveyance Self-test . . . . . . . . . . . . . . : Supported
Selective Self-Test . . . . . . . . . . . . . . : Supported
Save Data Before/After Power Saving Mode . . . . : Supported
Enable/Disable Attribute Autosave . . . . . . . : Supported
Error Logging Capability . . . . . . . . . . . . : Supported
Short Self-test Estimated Time . . . . . . . . . : 2 minutes
Extended Self-test Estimated Time . . . . . . . : 127 minutes
Conveyance Self-test Estimated Time . . . . . . : 14 minutes
Last Short Self-test Result . . . . . . . . . . : Never Started
Last Short Self-test Date . . . . . . . . . . . : Never Started
Last Extended Self-test Result . . . . . . . . . : Never Started
Last Extended Self-test Date . . . . . . . . . . : Never Started
Last Conveyance Self-test Result . . . . . . . . : Never Started
Last Conveyance Self-test Date . . . . . . . . . : Never Started
Security Mode
Security Mode . . . . . . . . . . . . . . . . . : Supported
Security Erase . . . . . . . . . . . . . . . . . : Supported
Security Erase Time . . . . . . . . . . . . . . : 255 minutes
Security Enhanced Erase Feature . . . . . . . . : Supported
Security Enhanced Erase Time . . . . . . . . . . : 255 minutes
Security Enabled . . . . . . . . . . . . . . . . : No
Security Locked . . . . . . . . . . . . . . . . : No
Security Frozen . . . . . . . . . . . . . . . . : Yes
Security Counter Expired . . . . . . . . . . . . : No
Security Level . . . . . . . . . . . . . . . . . : High
Serial ATA Features
S-ATA Compliance . . . . . . . . . . . . . . . . : Yes
S-ATA I Signaling Speed (1.5 Gps) . . . . . . . : Supported
S-ATA II Signaling Speed (3 Gps) . . . . . . . . : Supported
S-ATA Gen3 Signaling Speed (6 Gps) . . . . . . . : Not supported
Receipt Of Power Management Requests From Host . : Supported
PHY Event Counters . . . . . . . . . . . . . . . : Supported
Non-Zero Buffer Offsets In DMA Setup FIS . . . . : Not supported
DMA Setup Auto-Activate Optimization . . . . . . : Supported, Disabled
Device Initiating Interface Power Management . . : Supported, Disabled
In-Order Data Delivery . . . . . . . . . . . . . : Not supported
Asynchronous Notification . . . . . . . . . . . : Not supported
Software Settings Preservation . . . . . . . . . : Supported, Enabled
Native Command Queuing (NCQ) . . . . . . . . . . : Supported
Queue Length . . . . . . . . . . . . . . . . . . : 32
Disk Information
Disk Family . . . . . . . . . . . . . . . . . . : SpinPoint F1
Form Factor . . . . . . . . . . . . . . . . . . : 3.5"
Capacity . . . . . . . . . . . . . . . . . . . . : 640 GB (640 x 1,000,000,000 bytes)
Number Of Disks . . . . . . . . . . . . . . . . : 2
Number Of Heads . . . . . . . . . . . . . . . . : 4
Rotational Speed . . . . . . . . . . . . . . . . : 7200 RPM
Rotation Time . . . . . . . . . . . . . . . . . : 8.33 ms
Average Rotational Latency . . . . . . . . . . . : 4.17 ms
Disk Interface . . . . . . . . . . . . . . . . . : Serial-ATA/300
Buffer-Host Max. Rate . . . . . . . . . . . . . : 300 MB/seconds
Drive Ready Time (Typical) . . . . . . . . . . . : 12 seconds
Average Seek Time . . . . . . . . . . . . . . . : 8.9 ms
Track To Track Seek Time . . . . . . . . . . . . : ? ms
Full Stroke Seek Time . . . . . . . . . . . . . : ? ms
Width . . . . . . . . . . . . . . . . . . . . . : 101.5 mm (4.0 inch)
Depth . . . . . . . . . . . . . . . . . . . . . : 147.0 mm (5.8 inch)
Height . . . . . . . . . . . . . . . . . . . . . : 26.1 mm (1.0 inch)
Weight . . . . . . . . . . . . . . . . . . . . . : 610 grams (1.3 pounds)
Acoustic (Idle) . . . . . . . . . . . . . . . . : 2.7 Bel
Acoustic (Min Performance And Volume) . . . . . : 2.8 Bel
Acoustic (Max Performance And Volume) . . . . . : 2.8 Bel
Required Power For Spinup . . . . . . . . . . . : 2,250 mA
Power Required (Seek) . . . . . . . . . . . . . : 9.5 W
Power Required (Idle) . . . . . . . . . . . . . : 7.7 W
Power Required (Standby) . . . . . . . . . . . . : 0.9 W
Manufacturer . . . . . . . . . . . . . . . . . . : Samsung
Manufacturer Website . . . . . . . . . . . . . . : http://www.samsung.com/Products/HardDiskDrive/index.htm
S.M.A.R.T.
No. Attribute Thre.. Value Worst Data Status Flags
1 Raw Read Error Rate 51 99 99 000000000018 OK Error-Rate, Performance, Statistical, Critical
3 Spin Up Time 11 86 86 000000001446 OK Performance, Statistical, Critical
4 Start/Stop Count 0 99 99 0000000004B6 OK (Always passing) Self Preserving, Event Count, Statistical
5 Reallocated Sectors Co.. 10 100 100 000000000000 OK Self Preserving, Event Count, Statistical, Critical
7 Seek Error Rate 51 100 100 000000000000 OK Error-Rate, Performance, Statistical, Critical
8 Seek Time Performance 15 100 100 000000000000 OK Self Preserving, Performance, Critical
9 Power On Time Count 0 97 97 00000000349B OK (Always passing) Self Preserving, Event Count, Statistical
10 Spin Retry Count 51 100 100 000000000000 OK Self Preserving, Event Count, Statistical, Critical
11 Drive Calibration Retr.. 0 100 100 000000000001 OK (Always passing) Event Count, Statistical
12 Drive Power Cycle Count 0 99 99 000000000484 OK (Always passing) Self Preserving, Event Count, Statistical
13 Soft Read Error Rate 0 99 99 000000000018 OK (Always passing) Error-Rate, Performance, Statistical
183 Vendor-specific 0 100 100 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical
184 End-to-End Error Count 0 100 100 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical, Critical
187 Reported Uncorrectable.. 0 100 100 000000000018 OK (Always passing) Self Preserving, Event Count, Statistical
188 Command Timeout 0 100 100 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical
190 Airflow Temperature 0 59 54 000029130029 OK (Always passing) Self Preserving, Statistical
194 Disk Temperature 0 59 52 00002D130029 OK (Always passing) Self Preserving, Statistical
195 Hardware ECC Recovered 0 100 100 00000116705D OK (Always passing) Event Count, Error-Rate, Statistical
196 Reallocation Event Count 0 100 100 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical
197 Current Pending Sector.. 0 100 100 000000000001 OK (Always passing) Event Count, Statistical
198 Off-Line Uncorrectable.. 0 100 100 000000000000 OK (Always passing) Self Preserving, Event Count
199 Ultra ATA CRC Error Co.. 0 100 100 000000000020 OK (Always passing) Self Preserving, Event Count, Error-Rate, Performanc..
200 Write Error Rate 0 100 100 000000000000 OK (Always passing) Error-Rate, Statistical
201 Soft Read Error Rate 0 99 99 000000000018 OK (Always passing) Error-Rate, Statistical
Transfer Rate Information
Total Data Read . . . . . . . . . . . . . . . . : 12,331 MB, 17,466 MB since installation (8/30/2011)
Total Data Write . . . . . . . . . . . . . . . . : 7,668 MB, 10,681 MB since installation
Average Reads Per Day . . . . . . . . . . . . . : 17,466.00 MB
Average Writes Per Day . . . . . . . . . . . . . : 10,681.00 MB
Current Transfer Rate . . . . . . . . . . . . . : 80693 KB/s
Maximum Transfer Rate . . . . . . . . . . . . . : 82849 KB/s
Current Read Rate . . . . . . . . . . . . . . . : 7043 KB/s
Current Write Rate . . . . . . . . . . . . . . . : 73650 KB/s
Current Disk Activity . . . . . . . . . . . . . : 98 %
-- Partition Information --
Logical Drive Total Space Free Space Free Space Used Space
C: (Disk: #0) 97.7 GB 52.6 GB 54 % #########-----------
D: (Disk: #0) 97.7 GB 10.4 GB 11 % #################---
E: (Disk: #0) 400.9 GB 43.4 GB 11 % #################---
HD TUNE PRO 4.61
Registered to:
System Information
PCI Bus
Hard Disk Summary
No actions needed.
ATA Information
S.M.A.R.T. Details
Security Mode
Serial ATA Features
Disk Information
S.M.A.R.T.
