sta je FILTER="GRABMI_FILTER_PRIVACY"
nacke
CPU & Cooler
Intel I-5 12600 box
Matična ploča
asus rog strix B-660 wifi D4
RAM
2x16 gb Corsair rgb
GPU
asus geforce rtx-3060ti
Storage
Samsung 970 evo 1 tb
PSU
asus rog strix 650w
Kućište
LC power
Monitor
LG 23mp68vq
Miš & tastatura
red dragon
Laptop
Asus k52
Tablet
Huawei T10
Mobilni telefon
Huawei Mate 10 pro
Pristup internetu
  1. Optički internet
već sam postavio ovu temu ali bez odgovora i pomoći pa me interesuje
čemu služi ovaj filter, jer me stalno izbacuje iz igre C&C3:mad:
The Grabmi.exe tool is used to "grab" matching file information of applications. Grabmi.exe is a part of the Application Compatibility Toolkit (ACT). When you install, the ACT is located in Support\Tools\act20.exe in the Windows XP CD-ROM.
The Grabmi.exe tool can be run on one file or on an entire folder. Note that usually it is run on an entire folder to retrieve as much information as possible.
The matching file information is used to determine what programs and versions are located on your computer so that specific layering fixes, application help, and hard blocks can automatically be applied to the specific program that is found.
A cemu sluzi, to zna samo Bili :)
Probaj da ga iskljucis.
vrlo rado ali kako ?
Pojma nemam :crash: Nikada misam imao taj problem.
Opisi sta tacno izbaci, tj sta pise kada se zaglavi igra. Probaj da stavis da ti ta igra bude u compatibility mode za npr Win2000 (properties na ikonicu, pa compatibility) .
<?xml version="1.0" encoding="UTF-16"?>
<DATABASE>
<EXE NAME="cnc3game.dat" FILTER="GRABMI_FILTER_PRIVACY">
<MATCHING_FILE NAME="dbghelp.dll" SIZE="1030144" CHECKSUM="0xC9CCA318" BIN_FILE_VERSION="6.6.7.5" BIN_PRODUCT_VERSION="6.6.7.5" PRODUCT_VERSION="6.6.0007.5" FILE_DESCRIPTION="Windows Image Helper" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Debugging Tools for Windows(R)" FILE_VERSION="6.6.0007.5 (debuggers(dbg).051021-1446)" ORIGINAL_FILENAME="DBGHELP.DLL" INTERNAL_NAME="DBGHELP.DLL" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xFF021" LINKER_VERSION="0x60000" UPTO_BIN_FILE_VERSION="6.6.7.5" UPTO_BIN_PRODUCT_VERSION="6.6.7.5" LINK_DATE="07/08/2006 20:11:32" UPTO_LINK_DATE="07/08/2006 20:11:32" VER_LANGUAGE="English (United States) [0x409]" />
</EXE>
<EXE NAME="kernel32.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
<MATCHING_FILE NAME="kernel32.dll" SIZE="983552" CHECKSUM="0x4CE79457" BIN_FILE_VERSION="5.1.2600.2180" BIN_PRODUCT_VERSION="5.1.2600.2180" PRODUCT_VERSION="5.1.2600.2180" FILE_DESCRIPTION="Windows NT BASE API Client DLL" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Windows® Operating System" FILE_VERSION="5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)" ORIGINAL_FILENAME="kernel32" INTERNAL_NAME="kernel32" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xFF848" LINKER_VERSION="0x50001" UPTO_BIN_FILE_VERSION="5.1.2600.2180" UPTO_BIN_PRODUCT_VERSION="5.1.2600.2180" LINK_DATE="08/04/2004 07:56:36" UPTO_LINK_DATE="08/04/2004 07:56:36" VER_LANGUAGE="English (United States) [0x409]" />
</EXE>
</DATABASE>
probao sam compatibility mode sa win2000 ali tad nece ni da startuje igru
Au..:wall: ne znam.
A da reinstalirash win (sa predhodnim formatiranjem celog hdd-a)?
Meni radi bez problema na sp1.
To će se najverovatnije i dogoditi :exploder:
u svakom slučaju HVALA !
