Spisak Samsung B-die za Ryzen
Caridze
3.5" Floppy
https://forums.overclockers.ru/viewtopic.php?p=14779442#p14779442 uzeto odave
Single-rank:
Ballistix Elite 3466 MHz CL16 BLE2K8G4D34AEEAK 8Gb
KFA2 HOF4CXLBS3600K17LD162K 8Gb
Corsair CMK16GX4M2B3200C16 VERSION 4.31 [16-18-18-36 @ 1.35v]
Samsung OEM
8 GB M378A1K43BB1 CRC NON ECC UDIMM
8 GB M378A1K43BB2 CRC NON ECC UDIMM
8 GB M378A1K43BB2 CPB NON ECC UDIMM
8 GB M378A1K43BB2 CTD NON ECC UDIMM
8 GB M391A1K43BB1 CPB ECC UDIMM
8 GB M391A1K43BB1 CRC ECC UDIMM
8 GB M391A1K43BB1 CTD ECC UDIMM
GeiL Evo X (GEX416GB3200C16DC [16-16-16-36 @ 1.35v]
G.Skill Trident Z 3000 MHz CL14 F4-3000C14D-16GTZ 8Gb
G.Skill Flare X 3200 MHz CL14 F4-3200C14D-16GFX 8Gb
G.Skill Trident Z 3200 MHz CL14 F4-3200C14D-16GTZ 8Gb
G.Skill Trident Z 3200 MHz CL15 F4-3200C15D-16GTZ 8Gb
G.Skill Trident Z 3466 MHz CL16 F4-3466C16D-16GTZ 8Gb
G.Skill Trident Z 3600 MHz CL15 F4-3600C15D-16GTZ 8Gb
G.Skill Trident Z 3600 MHz CL16 F4-3600C16D-16GTZ 8 Gb
G.Skill Ripjaws V 3600 MHz CL16 F4-3600C16D-16GVK 8Gb
G.Skill Trident Z 3600 MHz CL17 F4-3600C17D-16GTZ 8Gb
G.Skill Trident Z 3733 MHz CL17 F4-3733C17D-16GTZ 8Gb
G.Skill Trident Z 3866 MHz CL18 F4-3866C18D-16GTZ 8Gb
G.Skill Trident Z 4000 MHz CL18 F4-4000C18D-16GTZ 8Gb
G.Skill Trident Z 4000 MHz CL19 F4-4000C19D-16GTZ 8Gb
G.Skill Trident Z 4133 MHz CL19 F4-4133C19D-16GTZ 8Gb
G.Skill Trident Z 4266 MHz CL19 F4-4266C19D-16GTZ 8Gb
Dual-rank:
Samsung OEM
16 GB M378A2K43BB1 CPB (CRC или CTD) NON ECC UDIMM
16 GB M391A2K43BB1 CPB (CRC или CTD) ECC UDIMM
Caridze
3.5" Floppy
Evo i testa od I.N. sa overclockers.ru za samsung C-die na agesa 1.0.0.6. OC i uporedjenje sa intel 1151 platformom. Uzeto 4 stika oem samsung.
7600k + ASRock Z170 Extreme6 vs r7 1700 + Msi b350 Tomahawk
https://www.overclockers.ru/lab/848...-gbajt-kogda-amd-vystupaet-luchshe-intel.html ovde je rezultat
Iz zanimljivog:
1. max oc po kloku je bolji na amd, dok na istom kloku intel ima bolje tajminge (ali prica kako je amd los za oc ram vise ne vazi)
2. povecanje napona na ram do 1,4V ne daje uvek bolji rezultat (vazi za obe platforme)
3. za oc ram kod ryzen na nekim maticnim je vazno fiksirati rucno veci tRFC (msi tomahawk to odradjuje automatski kako treba)
Caridze
3.5" Floppy
cikaunx9
3.5" Floppy
Ovo je super cena za 16GB stap. Nisam video kod brace na testovima, moze li i ova 16-ka da se nategne na 3000-3200 s obzirom da je dual rank?
cikaunx9
3.5" Floppy
OK, hvala. Verovatno uzimam ovo uskoro, pa cemo da vidimo sta ce da kaze...
cikaunx9
3.5" Floppy
Uzeo 2 stapa po 16GB. Cekam mounting kit za D14, pa cu okaciti ovde kako ide ovo sa Ryzenom.
Caridze
3.5" Floppy
@cikaunx9, ovo bi bas svima znacilo. I mene zanima kako se ponasa dual rank b-die (bas ti oem samsung) na ryzen.
Caridze
3.5" Floppy
Najzanimljivije je da u qvl asus x370 pro stoji da ti moduli su testirani i radili sa 4 dimm. T.j 64gb je radilo bez problema na deklarisanih 2133MHz. To moze biti korisno za one kojima treba workstation.
banesmrt
Flash Drive
2 x GSkill TRIDENTZ F4-3200C16-8GTZB
Hynix čip
Ima je u Gigamegadetu
radi na 3200 Mhz (3193.53 MHz) XMP 2.0 profil
Ploča je Asus PRIME X370-PRO sa fabričkim BIOS-om
cikaunx9
3.5" Floppy
Nabavio box cooler dok cekam mounting za D14, pa sam juce kresnuo novi komplet (1600x, asus prime x370 pro, 2x16GB 2133 samsung oem). Memorija radi na 2666-2800, to sam na brzinu uspeo da dobijem podesavajuci samo primary tajminge (16-16-16-16-36-52, 1.3V). Nisam uspeo da poteram na 2933+. Posto nema XMP profila, potrebno je pretpostavljam i sub-ove postaviti rucno, pa cu videti danas da to probam i da vidimo onda sta se moze izvuci.
Erik011
3.5" Floppy
Prevashodno racunaj da dignes minimum na ram voltage na 1.35v, mada mozes opusteno i 1.4v za svaki dan.
cikaunx9
3.5" Floppy
2800 MT/s prolazi i na 1.2v: http://prntscr.com/fov5bh
Medjutim, 2933 nisam uspeo da stabilizujem cak ni sa 1.35v za mem i 1.1v za SOC. Vrlo cudno ponasanje, masina radi usporeno, win se vuce, i kada pustim AIDA C&M Benchmark, brzine mem su manje vise ok, ali latencije i brzina CPU cache-eva su drasticno losije. Nesto mu se ne svidja od tajminga koje sam rucno postavio...
cikaunx9
3.5" Floppy
OK, mrda se polako... 2933: https://prnt.sc/fow005
Mrzelo me je vise da clear-ujem bios svaki put, pa sam podesio sve odjednom:
2933-16-18-18-18-36-69-2T
Gear Down: Disabled
ProcODT_SM: 68.8 Ohm
SOC Voltage: 1.1V
DRAM Voltage: 1.375V
Probacu sad jedno po jedno da zatezem da vidim sta joj tacno treba...
Caridze
3.5" Floppy
@cikaunx9, vidim sad da je ok. Ploca ga adekvatno postavila sama (514 je ok za 2933). Izgleda jedino timings da popustas ako hoces vise od 2933 (mozda cisto radi probe da popustis do 18-18-18 i pruzis na 3200)... Dual rank je to ipak, i nisu probrani cipovi kao na top gskill. Ali opet dobar rezultat za sada. Ako naletim na neke informacije nove u vezi tog ram kod Rusa - javljam.
cikaunx9
3.5" Floppy
Razliku pravi napon ili ovaj 68.8 Ohm djavo, posto se ne buni nista ni sa 16-16-16-16-36: https://prnt.sc/fowg88
Dobra mem, treba proveriti stabilnost pa videti da li moze jos malo da se izvuce.
Caridze
3.5" Floppy
@cikaunx9, super krenulo. Ne znam koliko ti je korisno (ipak je najverovatnije gskill 3200cl15 u pitanju), ali :
For example, I'm running 4x16 (64 Total) on a Taichi. They are running at 3200MHz (their rated speed). The only modification I had to make, was to bump the CAS down to 18. So instead of 15-15-15-35, I'm running 18-15-15-35.
Now, the important thing here, is that the chips on my RAM are Samsung B-Die. Those are the ones most people are having success with.
http://forum.asrock.com/forum_posts.asp?TID=5235&title=ryzen-ram-question uzeto odavde, pa ako zelis mozda i kontaktiras lika za detalje
upd. Evo jos malo podataka (original post trenutno nisam nasao):
Asus hero 6 bios 9945
4x16 3200 (samsung oem) Timings 18 DRAM Voltage 1.35, soc 1.1, ProcODT 48 1T
Caridze
3.5" Floppy
Evo podesavanja od brace Rusa: uspesno nasvirani SAMSUNG M378A2K43BB1-CPB 16Gb x 2 @ 3200Mhz 16-17-17-36-1T 1.375v Soc 1.1v , ploca asus x370 strix-f
cikaunx9
3.5" Floppy
Ne prolazi ovo kod mene, a nemam zivaca da isprobavam sve varijante...
Roger_Waters
3.5" Floppy
Corsair Vengeance LPX Black 8GB DDR4 Kit 2x4GB 2400MHz CMK8GX4M2A2400C14 u paru sa ryzen 3 1200 nije dobra kombinacija koliko sam shvatio...Ali se od najbolje razlikuje u tome sto ima 10% manji FPS u igrama, ako sam dobro video? Ostali benchmarkovi mi nisu bitni
Caridze
3.5" Floppy
@Roger_Waters, probaj na 2933MHz taj ram da poteras. To je bitnije za jace graficke, ali kad vec moze - sto da ne.
Roger_Waters
3.5" Floppy
@Caridze
ok. Jel bitan neki treci faktor kod RAMa pored frekvencije i prve latencije? Ne kapiram sta su B-die memorije ako je svaka memorija ko memorija samo je bitno na kojim tajminzima i na kojoj frekvneciji radi
ivanbass1
3.5" Floppy
B-die su memorijski chipovi koji su na tim memorijama, i oni su najraspolozeniji za OC.
Na istoj frekvenciji B-die nije nista brzi od bilo koje druge memorije.
