Ja imam KV-29FX66 iz 2003, u njegov servisni mod se ulazi na sledeci nacin, pa probaj, mozda je isto i kod tebe:
Service mode for KV-29FX66:
A. Prepare remote control for Service mode:
1.Press VCR/TV/DVD button until the TV LED lights.
2.Press and hold the yellow button for >5 sec until TV LED starts flashing quickly.
3.Press 99999. All three LEDs should light. The remote control is now set for service Mode.
4.To return remote to normal operational mode repeat steps 1 and 2 , then press 00000.
B. Setting the TV into Service Mode:
1.Prepare remote control for Service Mode as described above.
2.Turn on the TV.
3.Press the video standby button on remote control twice (NB! press the video standby button, not TV standby button).
"TT--"will appear on the screen to indicate that the set is in the service mode.
4.Press MENU on remote to obtain the service menu.
5.To navigate use up or down buttons on the remote control.
6.To enter into required menu item press the right arrow button.
7. To exit the service mode switch the TV set OFF and then ON.
Pozdrav
