Probaj usb receiver 2.4 GHz Wireless od nekog drugog Logi misa plus Logitech Connection Utility (mozda pomogne):
http://www.logitech.com/index.cfm/428/130&cl=us,en?softwareid=4338&osid=14
Mora se doslovce ovako odraditi kao u uputstvu, ali bukvalno, kad kaze jednom onda jednom, 5 puta klik znaci 5 puta klik, prati redosled od 1-6.
How to connect the cordless mouse to its receiver:
1. Launch the Connect Utility. (Note: You must have administrator rights.)
2. Turn on the mouse. If the mouse does not turn on, check the battery level.
3. Press and hold the left mouse button.
4. While still holding the left button, flip over your mouse.
* > If your mouse has a power or Reset button, briefly press once on the button while continuing to hold the left mouse button.
* > If your mouse has a slide switch for power, slide the switch off and back on while continuing to hold the left mouse button.
5. While still holding the left button, click the right mouse button 5 times, then release the left mouse button.
6. Click OK.
If your mouse failed to connect, please check the following then repeat the connect procedure:
1. Make sure the battery level is good or simply replace with fresh battery.
2. Try it on a different USB port and if possible use a USB extension to relocate the receiver closer to the mouse.
Edit:
Ooops, tek sad sam video da ti je bluetooth receiver. :wall:
