negovan90
Cenjen
Pozdrav svima, relativno sam nov u streamlabsu i u strimovanju, poceo sam da strimujem pre 3 dana na platformi trovo, i stream mi uopste nije fluidan, ima neko malo seckanje i lagovanje, dobijam ovu notifikaciju u stream labsu(slika ispod)
Pc spec:
CPU : AMD Ryzen 5 5600X 3.7GHz (4.6GHz)
GPU : INNO3D GeForce GTX 1060 6GB
Motherboard : ASUS PRIME X470-PRO
Ram : Hyperx 8gb 3200mhz
SSD : Kingston A2000 M.2 NVMe 500GB
SSD : Samsung EVO 860 500GB
Display: DELL Alienware AW2521HF/240Hz
Headset: HyperX Cloud II
Mouse: Zowie EC2-B CS:GO
Mousepad: SteelSeries QCK
Internet speed: 140-150/9-10
Zelim da strimujem u 1080p 60, prvo mi recite da li mogu sa ovim pc i internetom da dobijem to ili ne, ako mogu sta sam onda lose podesio u streamlabsu, hvala svima unapred na odgovorima, evo stavljam ispod podesavanja iz stream labsa.
Base Resolution:1920 x 1080, output:1920x1080
Downscale filter: lanczos(32 samples)
Fps type: common fps values
Encoder:Hardware(NVENC)
Rate control: CBR
Bitrate: i try 6500 and 5500
Keyframe: 0
Preset: Quality
Profile: high
Process priority: above normal
Color format: NV12
Yuv color: 709
Yuv color range: Full
Checked force gpu as render device
Pc spec:
Rate control: CBR
Keyframe: 0
Preset: Quality
Profile: high
Color format: NV12
Yuv color: 709
