moze li se naci negde kod nas?
http://www.cdrinfo.com/Sections/Reviews/Specific.aspx?ArticleId=24888&PageId=0
Po Seagate sajtu postoje i 410AS i 418AS, oba single patter, sa tom jednom razlikom u tisini. Takodje, na neweggu u ponudi su oba modela, 418AS je 5$ jeftiniji.I na drugim review-ima ista stvar, nalepnica 410, u win-u ocitavan kao 418 :trust:, ali mislim da je svejedno koja je oznaka ako ima jednu plocu od 500GB.... ne bi trebalo da bude problema prilikom kupovine jer novi disk je primetno tanji, i verovatno tesko da je moguce spakovati 2 ili vise ploce/a u to kuciste? Videcu jos ovih dana pa ako se budem odlucio za kupovinu prenecu utiske i hdtach/hdtune rezove ovde. Disk bi trebalo da je poprilicno brz.
:wave:
Misko, ako ga uzmes, obavezno prenesi utiske o brzini i buci, i ja se razmisljam izmedju ovog Seagate diska i WD 3200AAKS sinlge platter.![]()
:trust:ST3500410AS vs ST3500418AS
We wanted to make a note about 7200.12 model numbers, since this has generated quite a bit of confusion in our forums and other enthusiast forums. We found it strange that after having the 410AS model out for around a month Seagate also released the 418AS model with nearly identical specifications (the only real difference being acoustic performance). We contacted Seagate many times about this, and the following is the most up-to-date information we can provide you with.
The 410AS model adheres to industry standard "low halogen" specs and thus is more environmentally friendly than 418AS. The 410AS model also produces less noise than the 418AS model. That's about all we know, and to date Seagate has done little to distinguish these models from each other in their marketing material, which is odd.
I jel taj osiromaseni uranijum emituje dodatnu buku?sto znaci da je 418as model sa osiromasenim uranijumom namenjen za trzista treceg sveta (zato se, jel, i prodaje kod nas). kako god, i ja bih molio za utiske ako neko kupi ovaj disk. deluje da je dobra kupovina.
Ne moz' merge, ovo je tema gde da kupim.Moderatori moze merge ove dve teme:
http://www.benchmark.rs/forum/showthread.php?t=191056
i
http://www.benchmark.rs/forum/showthread.php?t=185200
