Update: If you’re having trouble with the “flash.ocx” file, please follow the directions below:
1. Browse to the C:\Windows\System32\Macromed\Flash folder.
2. Locate the flash9.ocx file and right click it and select copy.
3. Right click in a blank spot of the same folder and select paste.
4. You will then find you have a file called Copy of Flash9.ocx in the folder.
5. Right click the new file and select rename and rename to flash.ocx
