- AMD Ryzen 7 7800X3D @ DeepCool LT520 WH
- Gigabyte B650M AORUS ELITE AX
- 32GB Kingston FURY Renegade DDR5 RGB DDR5-6000 CL32-38-38 @1.35V
- Gigabyte AORUS RX 7900 XTX ELITE 24G
- Kingston KC3000 2TB + 1TB / Seagate BarraCuda 3TB 2.5"
- Zvuk
- NZXT Relay 2.0 + NZXT Subwoofer @ AudioQuest DragonFly Black v1.5 / Steelseries Arctic 1 Wireless
- Corsair SF750 80 PLUS Platinum
- Jonsbo D31 Mesh SC White
- Monitor
- Dell G2724D 27" QHD 165Hz
- Miš & tastatura
- Razer Pro Type Ultra & Razer Viper Ultimate Mercury
- Ostale periferije
- C1 55" & PS5 & Q990B
- Mobilni telefon
- Samsung Galaxy S24 Ultra
- Pametni uređaji
- Huawei GT2 Pro...
- Optički internet
- Mobilni internet
S obzirom da sam u fazi nabavke OLED monitora i da sam najblizi LG C3 42" modelu, razmišljam kako bih ga koristio na radnom stolu. S obzirom da bih definitivno izbjegao da je na nogare (zbog nemogućnosti podešavanja ugla gledanja onda) a otpada i mogućnost kačenja na zid jer imam elektropodesivi sto koji svako malo koristim - kao opcija se nameće jedino desk mount, tj. neka "ruka". Da li uopšte kod nas postoji neko kvalitetno rješenje a da nije Ergotron i slično od 200-300e
Koliko vidim ovaj mount je skroz ok s tim što bi mi trebao VESA adapter, ima li nešto slično kod nas?
WALI Single Monitor Stand Mount Arm, Fully Adjustable Gas Spring Desk Mount, with2 Easily Accessible USB 3.0 Ports, for Display Up to 35 Inch, 33lbs, GSMU001-W, White
Features: Design: Fits most flat or curved LCD/LED screen from 17” to 35”, and supports up to 33lbs with 75x75mm and 100x100mm VESA mounting holes. The two-stage locking system is compatible with 0.39"~1.8" thick desk for both C-clamp and Grommet Base. Fully Adjustable: The high-grade steel gas...
walielectric.com
VESA Monitor Adapter 50x50mm to 400x200mm
If you have a flat-panel TV with 200x100mm, 200x200mm, 200x300mm, 200x400mm, 300x200mm, or 400x200mm mounting holes and can’t find a compatible VESA mount, we have a solution! With this adapter, a 50x50mm, 75x75mm, and 100x100mm VESA mount will now fit screens with hole patterns up to 400x200mm!
vivo-us.com
