Samsung hdd problem i delays
va_milos
Imam problem sa bratovim hdd-om. U pitanju je Samsung HD103SJ od 1tb. Hdd je poceo da mu brise sam podatke. Pomislo sam da je zapatio neki virus ili trojanca, ali je hdd cist. Formatiran i sad ga trenutno testiram sa hdd regeneratorom koji prikazuje da ima preko 1600 delays detected. Za sada nema bad sektore, ali ima krs ovih delays, a tek je stigao do 50%. Okacicu i smart parametre, pa ako neko strucniji moze da prokomentari i razjasni. Svakako ga sutra saljem na reklamaciju.
Evo i slike.
Ultra DMA CRC Error Count promene vrednosti najcesce nastaju zbog loseg data kabla.
Ma promenio sam 5 kablova i nema nikakve promene. 3 kabla su potpuno nova.
Edit:
Evo sad nestade i particija. U sistemu ga ima, svi programi ga vide, ali se formatirana particija ne vidi.
Pretpostavljam da si probao i neki drugi SATA port :type:
Sve sam probao sto mi je palo na pamet. Jel znas mozda sta je ovaj delays sto je detektovao?
http://hddregenerator.net/hdd-regenerator-works.html
Permanent delays mean that the hard drive has sectors with long access time. A drive with permanent delays is actually failing drive and may cause data losses. You can try to regenerate such sectors using the "Regenerate all sectors in a range" option. Also, the delays can be regenerated in the “scan and repair” mode, if the following both conditions are met:
1. The hard drive has been completely scanned at least 1 time.
2. The hard drive does not contain bad sectors.
If you still have permanent delays, then the hard drive should be replaced.
